Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By Rufys
Thread: Second hand VE - Looks like resprayed?
    VE SS-V, V8, 6 Speed Manual
    Apr 2009
    Default Second hand VE - Looks like resprayed?
    hey all,
    had my Black VE SSV for just 1 month and i have notice that when i open up the driver and front passenger door, if i look in where the hinges are i can see the edge of the front quarter panels and they appear to be mostly white but "peppered" black.
    does this sound normal? or like the car has had a respray or front end rebuild?
    any other black VE owners able to check to see if its the same on their cars?
    car runs like a dream no mechanical issues, but would be curious as to whether its had a slap in the front previously.
    ill take a pic of the white peppered area to clarify what it is i am talking about.
    thanks,
    Timmo
    VE2 SV6 SPORTWAGON
    Feb 2006
    SA
    i reckon its normal, my silver ute was like that and that was new
    The Mad Dutchman
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    Quote Originally Posted by vicarious View Post
    umm.... sorry mate i have to disagree. definitely not normal.
    there's a series of videos that ive seen somewhere on this website that shows the VE production process from Holden.
    it's a facinating series of videos showing basically how the car is made.
    anyway, the car colour is painted inside and out well before its all put together... so everything is the same colour (door hinges, door frames, inside the boot and engine bay, everywhere... all the same).
    the whole thing is sprayed on a rotisiere from all sides (makes sence from a rust protection and quality control point of view).
    so no, if you can see white when the rest of your car is black, its definitely not normal.
    best way to double check is to look at the screws/bolts holding that panel in place when you lift the bonnet.
    if they havent been touched from factory, all the corners of the bolts are perfect- no stripping or deformation of any kind from the panel beaters rachet set tightening them up. there's no way to tighten a bolt without scratching it or deforming it a little. some panel beaters try to cover these marks by spray painting the bolts themselves to make it look neat, but then thats a dead giveaway because factory bolts arent painted at all.
    it's no big deal if its been repaired and resprayed, and if the only way you've noticed it is to look at the door hinges means its a quality job.
    and hey, if youre that worried, you could always touch up that area yourself.
    but no... definitely not normal, because thats not how VE's are made. wish i had the links to those videos to show you.
    show us some pics from different angles, lets try and see how much has been changed.
    if you really want to know that is .
    VE2 SV6 SPORTWAGON
    Feb 2006
    SA
    i think the OP means behind the front quater panels so it wouldn't be sprayed in car colour,anyway there is supposed to be a foam filler piece in there. If the front quarter panel was replaced it would of been resprayed properly off the car, but when the panel is on the car on the line the robot can't get all the small areas where primer is only required.
    The Mad Dutchman
    UFO's Avatar
    UFO
    Oct 2009
    found them!
    The series is called "Steel to Road - Building Holden Commodore"
    Steel to Road - Building Holden Commodore (Part 2 Body & Paint Shop) - YouTube
    The above link is part 2... about half through it'll show the paint process.
    No way you should see white on a black car.
    Those robots are amazing!
    VE2 SV6 SPORTWAGON
    Feb 2006
    SA
    Quote Originally Posted by UFO View Post
    found them!
    ahhh, read the OP problem and the video just shows the quarter panel on, hows a robot suposed to spray behind the quarter panel?, the white would be the rustproofing/primer
    The Mad Dutchman
    Apr 2009
    ill take a pic now and put it up so you can see what i mean
    thanks for the prompt replies also!
    VX SS
    Jul 2005
    East of Melbourne
    My nephew's brand new VE SS ute had issues with an area around the hinges not being painted properly, they removed the door and repainted the area around the hinges and re-hung the door. He noticed it shortly after taking delivery.
    Apr 2009
    this is what i mean, it shows up really white in the photo but it is dusted/peppered black.
    Commodore
    Jun 2004
    NSW
    TinSnips's Avatar
    TinSnips is online now Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    Rufys is offline Banned
    VE Series II Calais Sportwagon
    Aug 2011
    The panels are painted ON THE CAR ffs, not painted and then assembled. How is this anything but normal? lol
    VT Series 1 V6
    Jan 2008
    Hey mate,
    What's your opinion of the car as a whole after 1 month, are you happy with it?
    UFO's Avatar
    UFO
    Oct 2009
    Quote Originally Posted by Rufys View Post
    and who said any different? of course the panels are installed prior to painting. but its the rest of the car that's put together after painting.
    thats fair enough mate, but OP didnt mention anything about foam fillers.
    going by what he said here, i thought he was talking about the actual quarter panels paint job.
    and yes, the robot spray will most definitely get into anywhere you can see by opening the door... so you shouldnt be seeing any primer at all. it's either the galvanised coating (a matt silver colour), or paint colour.... not "mostly white but peppered black" as OP described.
    OP's description doesnt match the picture he took at all.
    anyway problem solved.
  15. #15
    Apr 2009
    Quote Originally Posted by Longman View Post
    Hey mate,
    indeed! i sure am, first V8 i have owned so i am in love haha. but even just the car as a whole is great. very happy with my purchase.
    i did notice in the photo it doesnt show the black spray on the white area, with flash off you couldnt even see the area i was talking about.
    but none the less theres enough of your who got yours from factory like that, so im happy with that response. thankyou all for your input.
    cheers,
    timmo.
  16. #16
    vesv6s2
    Oct 2011
    blakeviewsa
    Thumbs up looks like respry.
    when you open the doors, inside the gaurds,there is no paint had a new s-1 and new s-2 both the same.Go to show room you will see all same,.nomatter what colour,hope this helps:
  17. #17
    VE Ute
    Sep 2011
    Cool Spray behind door seals
    Mate you have nothing to worry about they are all like that..mine included. Does look ordinary though doesnt it
  18. #18
    2010 VEII SSV Redline Ute
    Dec 2011
    Hampton Park
    I'm jumping on the 'factory spec' bandwagon here. Brand spanking ssv and I got the same shit. Holden produce cheap vehicles in the grand scheme of things. Unfortunately in some areas it shows.
  19. #19
    VE SV6 ute
    Apr 2009
    vic
    ####ing who cares about abit of paint missing on the rear panel of something only the anal notice LOL
  20. #20
    vesv6s2
    Oct 2011
    blakeviewsa
    it s***ts you off when aFord owner points it out though and really LOL.
  1. what is high fill when getting a car resprayed?
    By admir87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2010, 06:01 PM
  2. Front Bumper Resprayed, How Much?
    By ZOMBIE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-12-2008, 09:24 PM
  3. Front Bumper Resprayed, How Much?
    By ZOMBIE in forum General
    Last Post: 13-12-2008, 04:36 PM
  4. Bonnet Resprayed Phantom
    By Shounak in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-10-2007, 01:30 PM
