hi every1 i am trying to put line converters in my ve sv6 ute and for the life of me i cant get the fasica off to get to the head unit can any 1 help me with it or is there another way to get into it????
I dont know if it would be the same with the newer systems. Mine if you pull from the bottom eventually comes off. I'd pull the gearstick back so you dont smash it, it does take abit to come.
take off the trim on the drivers side of the center console, you will get access to the radio plug in there
hi guys thanks yea iv been trying and trying for ages to get off the fasica, my mate wont wire up the line converter with out the fasica off for some reasion haha so yea thanks i try to pull it off like every 1 says but it just doesnt seam to work for me
Do what hakhawk said. Taking the facia off won't get you anywhere.
The trim should come out really easily (it's only clipped in) and you have access to all the wires going into the side of the Headunit![]()
Ryan
VE Commodore
If its the same as SSV, put your hand at the bottom of the stereo and let your fingers curl up underneath. Then pull. The fascia is simply 'clipped' onto a metal plate of the actual head unit itself.
I can't remember which one but its in one of the trim ones of theses
VE Commodore Service PDF's
Bonners is correct that is how you get the face plate off ^^^^ but to install a LOC you don't need to do this. you need to just pull the scuff plates off the drivers side they both just pull down there you will find the wiring harness and go for your life.
As i put in your other thread you may want this
http://www.mediafire.com/?uj7ob3j8pncud77
Check out my VE Commodore My Omega Mods
hey bigboss, download link not working. any chance you can upload file to somewhere else (like imageshack or something) ?
so do u need to take anything else off or just the stuff u said to install a LOC cause my mate for some reasion wont do it with out the fasica off and yea haha
