Results 1 to 7 of 7
Thread: Heater Hose Relocation
    VE SSV 60th Ann
    Oct 2010
    Default Heater Hose Relocation
    Ok guys this has been discussed through threads but I cannot actually find a direct link that says "this is how to do it"
    I bought the heater hoses from the early model commodore. Part number 92026765
    Now I understand that you disconnect the hoses from the firewall and then somehow reattach to the existing heater hoses when you have moved them to the spot you want.
    Question 1: On the heater hoses standard on the VE, they have a covering on them. Is this purely to protect the hoses from heat when draped across the motor. The reason I ask is that I saw a 'kit' using these two same 'early' model commodore hoses and it had some sort of sheath on them as well. Is it necessary
    Question 2: I was of the understanding that the best way to do the relocation was straight down the firewall to the gully next to the motor. Will these hoses allow me to do it this way. Or does it not matter?
    Question 3: how do you attach into the existing clamps?
    Now before anyone says things about other threads, yes I have read them. But I am a little confused about a couple of the specifics.. The clamp/joiner part is the bit really throwing me as is the 'sheaving' on the hoses
    Bonners White E3 Clubsport - SV Enhanced
    Wortec Brakes Distributor
    Ve r8 , VL turbo
    Oct 2011
    Camden
    Hey mate did mine thisarvo. I put the 90deg end straight onto the motor and ran them behind the wiring under the abs module. Once past there ran them across the thin steel brake line near the booster. You can still use the Spring clamps from the old hoses. Don't mix up the clamps as they are both different sizes.
    Now it's just a matter of trimming off the excess hose I cut approx 8-9inches off both. Was an easy job . If you want any mor info send me a pm
    Almost forgot I grabbed some hose wrap from pirtek but where the hoses are running I'm confident it's not needed
    SilverVH is offline Banned
    Nov 2005
    I retained the standard hoses and didn't cut anything when performing this mod. Mostly out of sight apart from across the firewall above the brake booster.
    A very worthwhile mod for any VE.
    Ve r8 , VL turbo
    Oct 2011
    Camden
    VE SSV 60th Ann
    Oct 2010
    Thanks mate. But I'm confused again. Those two early model commodore hoses are the same size. Why the comment about different size clamps
    Edit: hose wrap- what's that, how much etc. is it similar to what Holden use
    Sent from my iPhone using Tapatalk
    Ve r8 , VL turbo
    Oct 2011
    Camden
    Quote Originally Posted by bonners View Post
    The two fittings on the motor are 2mm difference and the clamps are an exact size so best not to mix them up. but both hoses still go on no problems (they're designed to stretch).it's quite easy once you pull it of and have a look.
    The hose wrap is just a plastic spiral to protect the hose. I didn't bother putting it on as it's not on anything sharp so can't be damaged. Not sure on cost I got the wrap from work we have it by the box for machinery
    VE Calais V 6.0L
    Aug 2011
    Cheers for the information guys.
    I will be trying this mod these holidays !
  1. Vp heater hose not conneted
    By VpBallperth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2011, 11:07 PM
  2. Heater hose grommet
    By maldotcom2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-08-2009, 09:36 PM
  3. Possible Heater Hose???
    By ceedy_18 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-05-2009, 09:27 AM
  4. VP on LPG heater hose setup
    By fishman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-04-2007, 11:30 PM
  5. can anyone help with VP on gas heater hose setup
    Last Post: 15-11-2006, 09:54 PM
