Results 1 to 9 of 9
Thread: How to disable Active fuel management
    VE SSV
    Mar 2011
    Western Australia
    Default How to disable Active fuel management
    I have a 2007 manaul ve ss
    I'm fitting a l77 crate motor to it
    Do I have to disable Afm, if so how would i doable it
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    AFM isnt active with manuals. Only Auto.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    aaronevolution's Avatar
    aaronevolution is online now Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    VE SSV
    Mar 2011
    Western Australia
    Quote Originally Posted by Sabbath' View Post
    So I will have no problem then considering my car is a Manual
    TinSnips's Avatar
    TinSnips is online now Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    An L77 will have all the DOD lifters and such, same as L76 (L98 is no more for holden) - but AFM won't be supported by your car, so should be fine. From memory though, and I can't recall why I think this - if you're fitting an L77 to car that was build to have an L98 (like your 2007) you need to swap the cam to an L98 cam - or tune the car to suit the L77. When holden do a motor swap, they retain the older cams.
    VE SSV
    Mar 2011
    Western Australia
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by TinSnips View Post
    When Holden do an engine swap they use the same model engine
    Silver Certified.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by jbourne_86 View Post
    Why do I have to have to swap the cam over to a l98 cam?
    I havent heard of this but it doesnt mean its not true.
    If you change your engine to one with different valve timing the ECU will not know this and the engine wont run too well as the ignition timing wont match the cam.
    Silver Certified.
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    ^^^ was a holden tech who told me this.
    Can't recall the exact reason for the cam swap though.
  1. Disable immobilizer?
    By Dti-dan in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-10-2011, 11:25 AM
  2. How to disable the sensors
    By tHe_sTiG in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 20-02-2011, 08:45 PM
  3. (AFM) Active Fuel Management
    By Super Coach in forum VE Holden Commodore (2006 - ?)
    Last Post: 06-05-2009, 06:05 AM
  4. disable alarm
    By smile in forum General Discussion
    Last Post: 13-04-2009, 11:47 PM
  5. Active Fuel Management for VE
    By smeg555 in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-04-2008, 12:19 AM
