Remove the propeller shaft and rubber coupling from differential flange. Refer to Propeller Shaft Replacement.
•Remove the propeller shaft heat shield. Refer to Exhaust Heat Shield Replacement - Center.
Important: Observe the orientation of the rubber couplings with reference to the differential flange and the transmission flange. This will minimize the potential of incorrect propeller shaft installation.
•Mark the rubber coupling (1) in relation to the differential flange (2).
Important: With the aid of an assistant or suitable jack support the propeller shaft (2).
•Remove the rubber coupling to differential flange retaining bolts (1).
Important: Observe the orientation of the rubber couplings with reference to the differential flange and the transmission flange. This recommendation will minimize the potential of incorrect propeller shaft installation.
•Mark the rubber coupling (2) in relation to the transmission flange (1).
Important: With the aid of an assistant or suitable jack support the propeller shaft.
Important: Torque prevailing nuts with are single use parts and must be discarded after removal.
•Remove the rubber coupling to transmission flange retaining bolts (1) and torque prevailing nuts (2).
Discard the nuts.
•Remove the centre bearing to body retaining bolts (1).
•Disconnect the propeller shaft (2) from the differential flange.
•Remove the propeller shaft (2) from the vehicle.
