Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By TinSnips
Thread: VE aircon problem.
    VE SS Ute
    Dec 2011
    Unhappy VE aircon problem.
    Hey there, I just bought a 07 VE SS Ute a few months ago for work. I've had no problems with it until the aircon starting playing up. I just had it serviced for the 90k log book service and after a week or so the temp of the aircon started to get warmer and warmer. So after doing some research on here someone sugguested to hold the demist button in for 10 seconds and the unit will reset itself and fix itself......
    Well thats not what happened.... since resetting it all it will do is blow hot air out at the screen and thats it!! You cannot change anything......
    I can't get it into the workshop that serviced it or Holden until after Xmas...
    Any ideas would be greatly appreciated
    Ve r8 , VL turbo
    Oct 2011
    Camden
    VE SS Ute
    Dec 2011
    ssv ute , Range Rover Vogue
    Mar 2010
    Peeramon
    Air-cons being air-cons, they like to go into politics after a while, and hence, they blow "hot air"
    If, as mentioned above hasn't happened, check if the clutch is kicking in, if not, it's probably out of gas
    I've never been poor, just broke
    Mar 2010
    Peeramon
    VE SS Ute
    Dec 2011
    Yep I think that was the original fault but after holding the demister button in and resetting it.... it does nothing now ..doesnt even change from the screen to any other zone!!
    TinSnips's Avatar
    TinSnips is online now Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    Could be the HVAC module not communicating. Mine crapped itself and had to be reset with a tech 2. Not sure if pulling the battery would do the same job though.
    VE SS Ute
    Dec 2011
    Yer that makes sense... what did you end up paying to get that fixed? Did you have to get that done thru Holden? Cheers
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    Nothing.. the module crapped itself while holden replaced the driver's seat the first time under warranty (long story, not important) - when they plugged everything back in and gave me back the keys, the AC was unresponsive - took them about 20 minutes to figure out that the module wasn't communicating and, fortunately, resetting it worked. Otherwise it was a new module.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    When u push the AC button can you hear the compressor click on?
    When u push and hold the demist button can you hear the actuators moving (have radio off and all doors and windows closed as they are fairly quiet)
    Silver Certified.
    VE SSV Manual
    Oct 2011
    Mandurah
    Drop your negative lead off the battery (Boot) for 30 seconds and reconnect the terminal.....Worth a shot.....
    VE SS Ute
    Dec 2011
    Have tryed the negative lead idea and once again no luck.. Thanks anyway worth a shot !
    VE SS Ute
    Dec 2011
    Nope can't hear the compressor kick in at all... and when you hold the button it just completly shuts down and restarts a few seconds later..
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Not clicking on is generally due to low refridgerant level..
    Silver Certified.
  1. Aircon problem... maybe
    By tropey in forum VE Holden Commodore (2006 - ?)
    Last Post: 06-06-2010, 05:08 AM
  2. Aircon problem
    By Pez in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-06-2009, 10:00 PM
  3. VE aircon problem
    By alkuku in forum VE Holden Commodore (2006 - ?)
    Last Post: 16-09-2007, 01:26 PM
  4. Aircon Problem
    By fudlop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-07-2006, 10:32 PM
  5. VT Aircon Problem!
    By Carnage in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-01-2005, 01:07 PM
