Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By Reaper
  • 1 Post By Sabbath'
Thread: Can the gear knobs be changed in the newer VE's?
    VE Commodore SS
    Dec 2011
    Central Qld
    Default Can the gear knobs be changed in the newer VE's?
    Ok, so Im guessing this has already been posted/asked before but I dont have anytime atm to look thru all the feeds on here... can only tell me if it is possible to change the gear knobs
    only on the newer VE's??? Its an ISOTTA if that helps
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by Bubbles86 View Post
    I have an aftermarket shifter on my VE. I presume it'd be simple enough to put an aftermarket knob on top. No comment about the knob that operates the knob.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    VE Commodore SS
    Dec 2011
    Central Qld
    Reaper's Avatar
    Aug 2004
    Pop shifter surround cover off, Undo the 4 screws that hold down the shifter boot, pop off the shifter from the shaft and then do the reverse for the new one.
    Reaper
    Reapers Black VP SS
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Reaper
    You forgot "Try not to knock yourself out when the old one comes loose"
    Post 2k
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    VE SSV 60th Ann
    Oct 2010
    Yep I use a momo one
    However on my new MGW shifter, I'm using a rip shift race knob
    I'll post a pic when installed
    Sent from my iPhone using Tapatalk
    Bonners White E3 Clubsport - SV Enhanced
    Wortec Brakes Distributor
    08 VE SS
    Nov 2009
    U might have to be a little rough pulling the old one off but it does corn off
    VE Commodore SS
    Dec 2011
    Central Qld
    So I've noticed there are 3 screws (installed using an allen key) with the knob... Is it still possible to replace?
    VE SV6 II Ute
    Aug 2009
    Melbourne, Victoria
    VE Commodore SS
    Dec 2011
    Central Qld
    This is it but in yellow... It's an Isotta
    Attached Thumbnails Attached Thumbnails Can the gear knobs be changed in the newer VE's?-image.jpg
  1. automatic gear knobs
    By PEAKN6 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-06-2010, 03:32 AM
  2. HSV 5 Speed gear Knobs
    By lil_oneblue in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2006, 07:00 AM
  3. Automatic Gear knobs
    By hotrod32 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-07-2006, 08:12 PM
  4. Changed my trans fluid finnaly, now car wont change gear sometimes.
    By venomous in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-10-2005, 08:59 PM
  5. 5 speed Manual gear knobs
    By vkberlina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-04-2005, 08:10 PM
Tags for this Thread
