Hi,
I got a Ve Calais V 2006 about 3 months ago and lately since the weather has been heating up my A/C had been cutting out on me!! I'll turn it on and after a few mins it will just stop! its very fustrating with a hot car and leather seats.Its just been for its 75,000km service and the battrey is borderline which i knew already and i will be replacing it soon but other than he said the car was prefect.It seems to mainley happen them its on the coldest Temp and seems to be okay on 17 Degrees from what i can tell at the moment.
had anyone had this problem before?
Thanks
Had the same problem with my 09 SS... Took it to Holden. They had to replace a pulley or something like that. But they knew the problem straight away and fixed it under warranty without any drama. I think it might be a common prob
I've got the same problem, I've been told there is a software update, let us know how you go.
Does the air stop coming out of the vents? If so the evaporator is icing up due to an issue with the evaporator temp sensor. It tells the car that the evaporator is warmer than it actually is so it gets colder and colder till it freezes and air cant pass through it.
If air keeps coming out but gets warm then it could be low refridgerant and simply need a regass.
Pulley or belt related issues generally result in the AC not working at all as its thrown the belt that drives the compressor.
Silver Certified.
I have an intermittent issue like this... If I give the car a boot sometimes the A/C stops being cold until I turn the system off and back on. It's like when I used to lose the belt except it's fixed if I turn it off and back on![]()
If you have lost a little gas over time, the compressor will stop when it get the low pressure signal on the refrigerant pressure. If you leave it longer, more gas will escape and it won't start the compressor at all
Current Ride: 2011 VE Sedan - In Voodoo of course.
Last Ride: 2004 Subaru Liberty GT, Twin scroll turbo, tuned, Bilsteins, sway bars, no rice, 420Nm
Also Own: 1964 EH Wagon, modified interior, minor modifications outside
you need to put some ac gauges on and see if its electrical, or a gas problem and go from there.
Had the same problem except the whole centre panel would turn off and the A/C would either stay on and not be able to be turned off or would cut out completely. I know someone at holden they told to me to pull the fuse out for the radio and a/c for 10 seconds, this fixed my problem but if it doesn';t i was told it would be the H_Vac Module. $450 from holden
Centre panel turning off is more likely a facia or radio issue.
Silver Certified.
thats what i thought too RiCeY but apparently the H-vac module controls half that centre panel.....
The facia is simply an input to tell the HVAC module what to do. It isnt powered by the HVAC module.
Silver Certified.
Thanks for your replies.its under a 4 year warranty so ill take it to holden and see what they find.the hair completely stops coming through the vents when it cuts out but it says it still on but after turning it off and on a few times it turns back on and dose the same thing depending how hot the weather is.
Is definately a software issue. Exact same problem with the wife's '06 Calais V about 2 years ago. Quick trip to my local dealer sorted it out, been fine ever since. Even got it fixed under warranty at the time even though it was well out of warranty (reminded them this was a known issue with upper spec VE/WM, and ECU should have been reflashed as a matter of course whilst being serviced by them during warranty period). From memory you could get a/c going again by turning off, then back on but not on 'auto' - instead turn the fan down very low manually, then gradually increase fan speed. Hope this is of some help, cheers
