Hi, just a little thing. More. Curious then anything, at night I've noticed when I use my power windows, my headlights dim slightly then go back to normal, every time, any ideas?
Btw sorry my car is an 08 ve ss ute
Do you notice anything else? If you put the aerial up or down do you get the same? When the a/c cuts in and out does it happen?
Quite common if so, because something would be putting additional load on the electrical system quite probably.
Ho hum, no Rocket Scientsist here just Space Cadets!
The ve aerial is always up, it doesn't change. But no I don't notice it with the air con or anything else, actually when I clutch in somtimes it does it
Same thing happens in my car mate, VE SV6 6spd manual.
I think its normal...
Same happens in mine - VE MY06.
All 3 VE's in our family do it.
I think it's just slightly more load being put on the electrical system, nothing to worry about though.
All normal don't worry about it they all do it
The fact that they do it does not make it "normal". It would suggest undersized components or faulty connections. Perhaps at the next service get it checked as it is repeatable.
It is just the load of the motors, they actually pull the voltage down a fair bit.
