Results 1 to 23 of 23
Like Tree6Likes
  • 1 Post By Onelittledeafman
  • 1 Post By RiCeY
  • 1 Post By pjdm1980
  • 3 Post By RiCeY
Thread: Latest VE Software
    2006 Calais V 6.0 ltr
    Dec 2011
    Qld
    Default Latest VE Software
    Hi guys I have recently bought a 2006 Calais V 6.0 ltr and just was wondering what the latest software number is as I'm getting a service done next week and want all the information for when it goes in
    Thanks Darren
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Which system?
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    Dec 2011
    Qld
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    They'll generally only do an update if there is a fault with one of the systems. As far as I know, each system has to be checked individually - it's not just a matter of plugging in the tech 2 and hitting update.
    Dec 2011
    Qld
    Oh ok its just that my battery died overnight recently i put a new battery in but now ive read on here about a software fix something about the bcm not letting the alternater charge the battery fully was wondering how i could tell if my car has had that update or not
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Theres a lot of causes of flat batteries in early VE's. The battery may have just been at the end of its life.
    The software updates were for the IPC and BCM modules. All other issues were related to poor earths, water entry etc.
    See how it goes with the new battery, if it goes flat again then further investigation will be required.
    Silver Certified.
    Dec 2011
    Qld
    Ok cheers is there any other issues I should be aware of that you know of
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Dec 2011
    Qld
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Swaybar D bushes fail and the swaybar can slide around and cause clunking. The revised D bushes are a lot better.
    Strut top bushes and bearings fail, steering doesnt self centre properly as it binds up at the bearing, can also cause clunking.
    Front spring clunk cause by the spring moving on the seat of the strut. Fixed by putting a rubber disc between the bottom of the spring and the strut.
    Harmonic Balancers start to come apart and get excess runout, you can see it wobble at idle if this is the case. Can also throw the AC belt, theres a revised bracket to prevent the AC belt coming off.
    Heater hoses leak at the quick connector, fixed by first removing crimp clamps and fitting worm drive clamps. If that fails replace the hoses.
    They are the main engine related ones...
    Silver Certified.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    And don't forget about the one where they catch on fire if you press the hazard light button and horn at the same time!
    Dec 2011
    Qld
    Ok thanks Ricey think I might need the D bushes cause there is a bit of a clunk when hitting bumps any ideas on how much for new bushes
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by pjdm1980 View Post
    Thats actually in the export manual. In the exported cars a flamethrower was fitted as an anti hijack device but to save money in Australia they didnt bother installing the flamethrower tubes so the car just sets itself on fire.
    Silver Certified.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by Onelittledeafman View Post
    I imagine they would be fairly cheap and you could even install them yourself they are just held in with a metal cap and two 13mm nuts on each side.
    Silver Certified.
  15. #15
    Dec 2011
    Qld
  16. #16
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Let me know if you want instructions on how to do it properly.
    To see if it is the D bushes jack the front of the car up and put axle stands under it. Grab the swaybar, it hangs down under the subframe either side of the engine, and try and slide it side to side. If it slides the bushes are cactus. It should be solid and not slide at all.
    Silver Certified.
  17. #17
    Dec 2011
    Qld
    Ok cheers will do that and yeah if you could send me instructions that'd be great thanks mate
  18. #18
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Basically raise the car at the front so the wheels are in the air.
    Support the car with axle stands, dont work under the car on a jack or anything else dodgy.
    Undo the 4 x 13mm nuts securing the U shaped metal caps that sit over the D shaped bushes then remove the caps themselves.
    The D bushes have a split in the base so just slide them off the swaybar.
    Clean the swaybar where it contacts the bushes then fit the new bushes. The new bushes have the split at the front of the bush.
    Fit the metal caps and the nuts but dont tighten yet.
    Make sure the swaybar is centralised then tighten the 13mm nuts.
    Job done.
    Note: You can access the nuts from above by removing intake piping from the throttle body and unclipping the airbox cover. Unplug the MAF and the breath tube and put the lot to one side. Just make sure ignition is off and that you plug everything back in before turning ignition on.
    Silver Certified.
  19. #19
    VE Calais V
    Jun 2006
    Christchurch
    Hey can anyone tell me if the rubber discs that fit under the front springs are able to be fitted to any model VE, eg 06 series one ? If so where do I get them from ?
  20. #20
    The X Man's Avatar
    The X Man is offline Donating Member
    VE SERIES II SV6 SIDI
    Feb 2010
    Be interesting to find out if there is some new software, in particular for the 6sp Auto that improves it's operation over the last 12 months. Do you know current version numbers for a SII SV6 RiCeY?
  21. #21
    bladerunner's Avatar
    bladerunner is offline AUSTRALIAN MADE AND OWNED
    VE SS UTE
    Nov 2010
    brisbane nth
    Quote Originally Posted by The X Man View Post
    try this site;TIS,its for yank gm vehicles but ours are no different,all updates are the same, oz or yank, put in your vin number, ignore the right column, it should do the rest.
    im out of my mind at the moment...please leave a message
  22. #22
    The X Man's Avatar
    Feb 2010
  23. #23
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by stirringaxe View Post
    Yes they fit all, any Holden parts will have them in stock. You have to dismantle the strut to fit them so it would be very wise to also fit new strut top bearings and bushes at the same time.
    Silver Certified.
  1. Thumbs Up For Latest Changes!
    By 1991_Vn2nV in forum Site Feedback / Site Problems
    Last Post: 25-09-2006, 11:59 PM
  2. my latest mod
    By 94vrexec in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2006, 12:10 PM
  3. Latest Craze In The US
    By AussieHolden in forum General
    Last Post: 14-04-2006, 05:03 PM
  4. the latest news
    By VR_WAGON_BORGY in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2006, 12:18 AM
