Page 1 of 2 12 LastLast
Results 1 to 25 of 50
Like Tree1Likes
Thread: United Premium 100
    2010 VE SV6 Ute and 2010 VE SSV Sedan
    Nov 2009
    Default United Premium 100
    I've done a google search, and can only find discussion on this fuel on other car forums (not holden) and a little bit of talk on LS1.
    Anyway, I've noticed some United Servo's are selling Premium 100 fuel, which has a 10% Ethanol blend in it.
    Premium 100 | United Petroleum
    There is a United servo near me that is selling it, so I'm thinking rather than filling up with BP Ultimate like I usually do I will give this stuff a go, and see if Steve (mace) can get anymore out of the tune.
    My 'concerns' are as to how it'll go in the 3.6L SIDI, I assume it should be fine, and I'm wondering if others have or are running this fuel in their VE's?
    If you are, have you noticed anything, positive and negative gains etc?
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    You can obviously give it a go but just remember on long road trips or if your somewhere, where there's no 100 octane you'll have to settle for 98 which may make the engine retard the timing
    Nov 2009
    Quote Originally Posted by Munz View Post
    I was thinking about that happening, I've sent MACE an email to see what he says.
    Jarp's Avatar
    Jarp is offline Surely You Jest
    SV6 MY10
    Dec 2009
    I've read reasonable gains can be made from the E85 tune...the LLT is dynoing at around the 280RWHP (208RWKW) in the States (only read one reference though). Would just be necessary to travel with hardware/tune to revert back to if necessary.
    Nov 2009
    I'm going to give the E85 a go Jarp.
    I was talking to Steve and I didn't realise the servo down the road from me sold it, so I'll give it a crack, see how it goes.
    Jarp's Avatar
    SV6 MY10
    Dec 2009
    Excellent man...am looking forward to hearing your results. From the reading http://camaro5.com/forums/showthread...71#post3344260 it sounds very promising although maybe still a couple of issues.
    Nov 2009
    Yeah I'm going to be interested as to what results this brings, I'll wait for the OTR and then start playing with the fuels.
    I've found this aswell,
    Oz Garage S02E06 Online - E85 Fuel | OzGarage
    Nov 2009
    Jarp's Avatar
    SV6 MY10
    Dec 2009
    Supe's Avatar
    Supe is offline Supe
    VE Calais 6.0
    Jan 2008
    Rural NSW
    I only use BP Ultimate, I would never put Ethanol in my car regardless of it being designed to run on it or not.
    VE2 SV6 SPORTWAGON
    Feb 2006
    SA
    Quote Originally Posted by bigjim92 View Post
    im not 100% sure,but i believe that the earlier sidi's aren't suitable for e85
    The Mad Dutchman
    aaronevolution's Avatar
    aaronevolution is offline Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    Shell used to have a 100 octane fuel called V-Racing. I'm not sure how it compared to V-Power 98 though.
    Jarp's Avatar
    SV6 MY10
    Dec 2009
    Quote Originally Posted by vicarious View Post
    Yeah Vicarious that is right only the SIIs are sold e85 compliant so would void warranty as will the tune ect...
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    Quote Originally Posted by aaronevolution View Post
    V-racing was 98oct + 5% ethanol, it seemed ok but I could not justify the extra 7c per/L on top of V-power
  15. #15
    VE MY10 SV6 A6
    Feb 2010
    Regional South Australia
    Quote Originally Posted by Jarp View Post
    E85 can be used on all models from MY10 onward, with the exception of the 3.6 until the MY12 was released.
    Quote Originally Posted by Dv8eD View Post
    Does anyone know how to pop the reverse sensor back into its spot without removing the rear bumper?
    Quote Originally Posted by Rufys View Post
    1. Remove the rest of the car from the rear bumper. Pop the sensor back into place. Re-attach the car to the bumper. Personally, I reckon it would be easier to remove the rear bumper.
  16. #16
    Nov 2009
    The reason why the ethanol fuels can be used on the Series 2 from factory is because Holden added a sensor to the fuel system, this sensor detects the ammount of ethanol in the system and the computer deals with it.
    Jarp, you'll most likely try the E85 before me as I won't be trying it until I've got the OTR, so I will be very interested to see your results.
  17. #17
    Jarp's Avatar
    SV6 MY10
    Dec 2009
    Was the sensor the only change...no changes to fuel pumps, injectors etc? That second clip you put up testing the fuels against each other was interesting. Based on that clip I don't think we'll see quite the same results as the Camaro because I think the Americans can only get 92ron (is this correct?) so if you run 98 already in Oz the gains won't be as significant. I put 10% in today just as a prep
  18. #18
    e3 clubsport r8 m6
    Nov 2011
    I think Holden changed more than just sensors in E85 compatable 6.0 if i remember correctly they also had to change valves to hardened type valves and made some changes to fuel delivery system ie fuel rails etc because the high ethanol content eats away at the plastic/rubber in the fuel system.
    I read that in wheels or motor magazine (cant remember it was back in 2010) when they dynoed E85 6.0 to see if it made any more power because E85 is suppose to give more mid range power/torque, the results showed no increase in power or torque
  19. #19
    Nov 2009
    All the reading I've done, the only mention of changes between series 1 and 2 is that addition of a sensor to read the ethanol content, I've read nothing about changes made to valves, pumps, lines etc...
    In regards to the dyno results, as shown in the video's above, on a stock car you probably won't notice anything, but a tuned/modified car is a different story, as the video shows.
  20. #20
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Quote Originally Posted by adr8 View Post
    If you have a look at the fuel system (even in a VX/Y/Z) there's pretty much no rubber hosing in them anyways - the only hose I managed to find that was plastic was the one coming off the fuel tank into the charcoal filter. It'd be interesting to see if they have a different fuel pump though.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
  21. #21
    Jarp's Avatar
    SV6 MY10
    Dec 2009
    Cheers bigjim...just to add it also seems that FI and higher compression engines show increased benefit of e85 use.
  22. #22
    Nov 2009
    Correct, well according to those video's anyway.
  23. #23
    The_Doctor is offline Banned
    VE SSV Series 2 Redline
    Sep 2011
    I have the Series 2 so if i could get E85 in WA i would love to try it, but alas not available in the West. Unless my car said specifically that is was E85 suitable i wouldnt be using it.
    Ive seen it for sale in Thailand 6 months ago, premium unleaded(98 RON) was 33 baht/Ltr ($1.05) and E85 was 22 Baht/Ltr ($0.70)
  24. #24
    e3 clubsport r8 m6
    Nov 2011
    i am only referring to V8 not the V6 I definitely know they made some changes I read the article some time ago so I cant remember exactly what was changed but it was more than just sensors
  25. #25
    dmacey's Avatar
    dmacey is offline Think about it,
    SSV Series II Sedan Manual
    Sep 2011
    File injectors need to accommodate increased fuel volume required to use E85, from memory I think it's about 30% more volume.
    Is this it?
  1. shipping to the united states
    By 85SS/85GN in forum The Pub
    Last Post: 21-09-2009, 09:34 PM
  2. united fuels
    By Boonz in forum General
    Last Post: 05-09-2007, 08:22 PM
  3. e-10 petrol at united servo's
    By pcp20us in forum General
    Last Post: 05-05-2007, 06:25 PM
  4. Question from the United States
    By farstarr in forum General Discussion
    Last Post: 07-04-2006, 01:00 PM
  5. Commodore Cop Car in United Arab Emirates
    By Butters in forum The Pub
    Last Post: 23-10-2005, 10:00 AM
