Results 1 to 4 of 4
Thread: Bluetooth
    2006 VE Omega / Look-a-like SSV
    May 2011
    Default Bluetooth
    Hey guys,
    Anyone know where I can buy a Bluetooth module from?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Your nearest Holden Dealer?
    Or any audio place if you are just after an aftermarket Bluetooth kit.
    Visit my Facebook page
    May 2011
    WM Caprice
    Aug 2007
    I use an ABT510 bluetooth unit that I bought from WES compopnents in my work Omega. It works quite well. http://wesnews.wescomponents.com/wesnews/WN269ABT.pdf I'm not sure the link will work, as you may need secure access to the website, but it's basically a small battery powered unit that plugs directly into any front panel aux plug (3.5mm audio plug). It's not fully automatic, but all you need to do when you want to make or receive a call is to select the aux input on your radio. It also comes with a mounting unit to remote mount it away from the radio if you want to. At less than $50, it's a good option.
  1. VE Bluetooth
    By dale762308 in forum VE Holden Commodore (2006 - ?)
    Last Post: 02-05-2012, 01:05 PM
  2. VE Bluetooth
    By PDG888 in forum VE Holden Commodore (2006 - ?)
    Last Post: 30-07-2011, 06:40 PM
  3. ve ssv Bluetooth
    By worked ssv in forum VE Holden Commodore (2006 - ?)
    Last Post: 26-07-2011, 10:35 PM
  4. Ve ss bluetooth
    By peteyb12 in forum VE Holden Commodore (2006 - ?)
    Last Post: 16-02-2011, 04:09 PM
  5. Bluetooth on SV6
    By ads1972 in forum VE Holden Commodore (2006 - ?)
    Last Post: 23-12-2010, 10:04 PM
