Results 1 to 2 of 2
Thread: VE SS Ute steering Angle Sensor fault
    VE SS Ute
    Dec 2011
    sunshine coast
    Default VE SS Ute steering Angle Sensor fault
    hi,
    i have a 2008 SS Ute manuel and i installed hm headers and after i installed them i got the stability control symbol flash on my dash and beep to let me know that the stability control was off.
    i could not turn the stability control back on with the button. when i start the ute i can use the button but sometimes after about 2min warm up the stability control off flashes up or other times it
    wont come up until about 100m up the road. when i take off from the curb and full lock to do a u-turn in the street the front right with bind up and make a horrible grinding noise until i touch the
    brakes. once again its only happens some times. i got a friend to plug a computer into the ute and it said the ute had a steering arm sensor fault and thats all.
    where is the steering arm sensor and has any one had the same noise in the front when turning
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Steering Angle Sensor is under the clockspring on the steering column.
    Silver Certified.
  1. Is this a typicult CAS(crank angle sensor) fault
    By zac_sa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2011, 12:10 AM
  2. VR Cam Angle Sensor
    By BRiNGiT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2010, 12:15 AM
  3. Adjusting the angle steering wheel / steering column
    By Kabooooom in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2010, 05:12 PM
  4. Cam angle sensor.
    By Haydz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2008, 11:11 AM
  5. crank angle sensor fault
    By shumway in forum V6 Development And Modification
    Last Post: 06-02-2007, 05:34 PM
