Results 1 to 14 of 14
Like Tree3Likes
  • 2 Post By UFO
  • 1 Post By Hektic
Thread: VE drivers door lock
    VE SV6
    Apr 2009
    Default VE drivers door lock
    Hey guys
    Last week I had my stereo done. Got all new speakers, a 5 chan amp and sub installed by a reputable company. The system works great and love it. edit was working well...
    However, after I got my car back I found a problem. When I go to lock my car with the remote all passenger doors lock but the drivers door does not. Can only lock it when I insert key into door lock and lock that way.
    Same situation when I unlock. Push unlock on remote and it will unlock all passenger doors and leaves the drivers door locked. I then have to put key in door and unlock it that way.
    If I just use key in the door lock all doors will lock and unlock. Its only when I use the remote that the drivers door will not lock or unlock.
    Also when using the lock, unlock buttons on centre console all passenger doors lock/unlock but not drivers. Same deal with auto lock at speed and unlock when gear stick is moved into Park.
    Took it back today and they spent 2 hours on it checking it. They said that all the connections and wiring seem fine and that the motor that drives the lock won't start. They believe that has seized and is causing the problem.
    They have rang up Holden and booked it in to get looked at.
    Just thought I would see if anyone else has had a similar problem?
    Ve r8 , VL turbo
    Oct 2011
    Camden
    Sounds like they've bumped the wires to the door lock somewhere . Especially when they've just fitted the stereo
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    got a multimeter?
    see if power is going to door actuator when you press remote key.
    seriously doubt motor has seized.
    you said you got new speakers. did you get new wires with that?
    I reckon they've damaged the wires coming into the door.
    multimeter will tell you straight away if its wires or door motor. i reckon its wires.
    VE SV6
    Apr 2009
    Haven't got a multimeter and I dont really wanna pull my door apart either.
    Anyway its back at the shop today because I got a new problem after I picked it up yesterday. Whenever I turn the volume over 15 it just cuts out and I have silence.
    This is getting really annoying.
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    If they havent done the stereo install properly, i wouldnt trust that this is a seperate, coincidental incident that the door lock has stopped working on its own.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    Ve Sv6
    Sep 2008
    Shepparton
    Stereo installs just aren't that hard...did they just swap the speakers in the doors?...........as for the stereo cutting out thats dodge as either a very bad install or faulty amp
    calais06's Avatar
    calais06 is offline Donating Member
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    Its because the cable was put into the 'clip' type thing in your door for the handle, but it needs to be pressed down into a plastic/rubber groove. If they didn't do this your door lock may move a little when u lock it from inside but not do anything.
    I had the same issue, just take the door off and check its all connected properly.
    From memory the screw are along the bottom, one below the arm rest (deep in the door) and one under the cap on the handle.
    Calais57's Avatar
    Calais57 is offline Donating Member
    VE Calais V 6.0
    Jan 2009
    Blue Mountains, NSW
    Yep. That's most likely the problem. I have done it myself too. Just take trim off and check or better still get the stereo place to do it!!!
    VE SV6
    Apr 2009
    Car was back at the stereo place all day. Reason for audio cutting out was one of the wires connected to amp had come loose/not connected properly and was causing it to short. Works great now but will wait and see...
    Also they fixed my lock. Im not sure what they did but it had something to do with the module/circut board for the lock and I dunno but main thing is its fixed and works like it used to.
    Thanks for the help.
    Ve Sv6
    Sep 2008
    Shepparton
    Module/Circut board for the lock?............what did the wire the stereo into that??? good to hear all is well now
    UFO's Avatar
    UFO
    Oct 2009
    module circuit board of the flux capacitor.... those damn flux capacitors... always very tricky when it comes to stereo installs .
    glad its all working now though.
    Hektic's Avatar
    Hektic is offline Donating Member
    2006 VE Omega Impulse Blue
    Jun 2010
    With The door simular thing hapend to me with the passenger side door only though, wouldnt open with the central lock.
    The problem Was The cable that is conected to the iterior door handle wasnt attached properly, the cable has a mounting clip to keep it secure it came loose from there so ass you pull the handle to open the door. The cable is loose and just pulls with the handle rather then unlocking your car.
    The Mounting point is located on the inside of the door, Close to Where the out door handle is.
    hope that helps.
    http://forums.justcommodores.com.au/...lue-omega.html
    Check Out my 2006 VE Impulse blue Omega
    VE SV6
    Apr 2009
    Quote Originally Posted by UFO View Post
    LOL He rambled some crap out but I cant remember. Probs tried to make it sound all technical when it was something simple that shouldn't of happened... Not to worried as all works well
    UFO's Avatar
    UFO
    Oct 2009
    hahahaha... exactly .
    least they fixed it all ok now .
  1. Drivers Side Door Lock
    By nstone63 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-08-2010, 12:54 PM
  2. drivers door lock problem.
    By Maccasmack in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-05-2010, 05:19 PM
  3. [VIC] WTB Drivers door lock VN-VS with key
    By westbad in forum Swap / Wanted to Buy / Trade
    Last Post: 28-08-2009, 08:47 PM
  4. VS Drivers Door Lock
    By PsYko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2006, 10:02 PM
  5. Drivers Door Lock
    By S Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-07-2005, 09:19 PM
