Results 1 to 5 of 5
Thread: 08 sv6 problems?
    ve sv6
    Jan 2012
    tamworth
    Default 08 sv6 problems?
    hey, new to the forum and just after advice. i have a 2008 ve sv6, purchased 7 months ago with 16,000 kms on it. it not has 30,000 and the problems are starting. when the car has been in the sun for a period after driving for a few minutes the stability control will turn off and you are then unable to turn it back on. once this starts its not far behiend when the gear box does not change through the gears, the car is an auto. it was drop down a gear and rev to 4-5000 revs for a period then will change and keep doing it over and over again. and for the past week or so when its having the gear problem you may go to put your foot down to accelerate and it will not do anything you have to take it off completly then try again. took the car to the local goodyear who i have always delt with and due to the fact that the car was not having the issue when it was there they could not pin point it. am i up shit creek without a paddle? any advice would be great!
    thanks
    2010 VE SV6 Ute and 2010 VE SSV Sedan
    Nov 2009
    Take it back to Holden and get them to check it out, something is clearly wrong.
    ve sv6
    Jan 2012
    tamworth
    its outside of the warranty period, would i be up for alot of money to get it checked?
    VE SS series 2
    Aug 2011
    Orange
    Generally not. A scan usually doesn't cost much. The repairs however COULD be a different story.
    ve sv6
    Jan 2012
    tamworth
    thats the part im scared about, the car is amazing when it works properly.
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. VZ SS random problems starting and also lock problems.
    By alista in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2010, 11:23 PM
  3. vs problems
    By vsdrifter889 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-04-2010, 02:09 PM
  4. Id like to know common problems with air con in vt so i can diagnose my problems
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 03:21 PM
  5. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
