Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By bonners
Thread: DashCommand for iPhone with OBD WIFI
    VE SV6
    Nov 2010
    Western Australia
    Default DashCommand for iPhone with OBD WIFI
    So I'm wanting setup my iPhone with DashCommand, and I think I've got it worked out but I just want to make sure. My car is the alloytec SV6 and I've had a look around and found this:
    App Store - DashCommand - OBD-II gauge dashboards, scan tool, and vehicle diagnostics
    and
    eBay Australia: Buy new & used fashion, electronics & home d
    Are there any cheaper or better performing devices? Will it be just plug in and play or is there some configuration needed that I should be aware of?
    Any comments are appreciated
    VE SSV 60th Ann
    Oct 2010
    There might be cheaper, but if this is the route you are choosing, then the PLX wi-fi device is by far the best of the lot
    And dash command is great software
    Bonners White E3 Clubsport - SV Enhanced
    Wortec Brakes Distributor
    VE Omega
    Nov 2010
    If you want to save a bit of $$$ and your a little techie and you have a iPhone 4 or below (because iPhone 4s jailbreak is not out yet but should be soon) you could use this software
    roqyBluetooth
    with a bluetooth OBD2 reader (much cheaper than wifi) and you would be sweet.
    Check out my VE Commodore My Omega Mods
    2009 SS Atomic Sportwagon
    Apr 2010
    hurstville
    I have the Torque app on my samsung galaxy s2 phone linked via bluetooth to an OBDII module and works a treat.So many different guages you can add.
    VE SV6
    Nov 2010
    Western Australia
    To the people that are using bluetooth, has anyone experienced delay problems? I read that wifi was better because it had a quicker response time. Is that true?
    VE Omega
    Nov 2010
    There is no perceptible lag using my cheap bluetooth unit
    VE Omega
    Nov 2010
    Or you could use this.
    Buy Now | GoPoint
  1. Replies: 9
    Last Post: 15-01-2012, 07:17 PM
  2. Dashcommand Vehicle specs for VE SV6 SIDI? Anyone got them?
    By WallyBasher in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-08-2011, 01:04 PM
  3. Anyone used a prepaid wifi modem?
    By axemurderer101 in forum The LAN Lounge
    Last Post: 29-04-2010, 02:17 PM
  4. Wii Wifi Connection- Mariokart
    By EvoVIIIJDM in forum The LAN Lounge
    Last Post: 02-07-2008, 08:06 PM
