Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Like Tree11Likes
Thread: VE won't start
    VE Omega
    Nov 2009
    Here
    Default VE won't start
    Ok guys help me out here. I had my VE serviced today by a friend and all we did was oil and filter. At the same time we did tried doing the pulleys, but the Harmonic balancer wouldn't come off and we gave up and just put the belt back on. Friend said to post here and chain might have slipped back 1 click. We haven't done anything at all to the car.
    When I start it it sounds like it does when it does the starter motor thing where it ticks but never starts, if I give it pumps of the pedal it starts after about 10 seconds and the engine sounds like it is going to blow up. It gives off a really loud noise from the engine. I am at a total loss about what the hell it could be?
    Please guys I need some help.
    P.S Battery is fine, terminals are fine and everything is connected correctly.
    Ve r8 , VL turbo
    Oct 2011
    Camden
    VE Omega
    Nov 2009
    Here
    Looking for a more productive comment than this Potta, got any help to offer?
    VE MY10 SV6 A6
    Feb 2010
    Regional South Australia
    I'm by no means "mechanically inclined", but maybe when you stuffed around with the harmonic balancer, you damaged the sensors in behind it or something? Personally, I'd be getting a mechanic to take a look.
    Quote Originally Posted by Dv8eD View Post
    Does anyone know how to pop the reverse sensor back into its spot without removing the rear bumper?
    Quote Originally Posted by Rufys View Post
    1. Remove the rest of the car from the rear bumper. Pop the sensor back into place. Re-attach the car to the bumper. Personally, I reckon it would be easier to remove the rear bumper.
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    VY SS
    May 2011
    Auckland
    Ticking starter is almost always a flat battery. Try jump it even if you dont think its flat, doesnt hurt to try.
    Or will run as long as your giving it gas? Your post is a little hard to decifer
    Is the check engine light on?
    Check ht leads are tight on plugs
    Check nothing's been unplugged (ie airflow meter etc)
    I can't see how you could have possibly slipped a timing chain tooth.
    In what way does it sound like it will blow up?
    Ve r8 , VL turbo
    Oct 2011
    Camden
    Quote Originally Posted by Z3RO View Post
    Sorry but there's not much else I can reccomend to help you with. You say the starter motor ticks and won't start (flat battery or starter solenoid). But then in the next sentence you say if you pump the throttle it starts and makes horrible sounds.
    All I can say is either get it taken to Holden or check you haven't broken any wire or sensors when working in the bay.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    How would the chain have slipped a tooth?
    How do you know the battery is fine?
    Silver Certified.
    VE Omega
    Nov 2009
    Here
    Quote Originally Posted by Lumps of cheese View Post
    Mate, get it seen to by a mechanic pronto. And stop letting your mate touch your car.
    Mate IS a mechanic, that is why I let him touch it. No one that isn't qualified is touching my car.
    Quote Originally Posted by m1lky View Post
    I don't have a clue WTF is wrong with it, never heard a car sound like this. It sounds likes like a squeal in the engine when I get it to start.
    Air flow was unplugged but plugged back in. Now I have no idea.
    Quote Originally Posted by Potta9 View Post
    I might have to have RACQ tow it to a mechanic on Monday. I will have them tow it to someone that specializes in Holden but won't charge me Holden's obscene prices.
    Quote Originally Posted by RiCeY View Post
    Battery is fine because the car will fire with accelerator. being pumped and all accessories work as per usual.
    VE Omega
    Nov 2009
    Here
    I called RACQ to come out and "look at it". I will get them to scan tool it and see if there is any faults or what is wrong.
    2007 VE Lumina
    Apr 2011
    VE Omega
    Nov 2009
    Here
    RACQ have no idea what is wrong with it. They said it's going to have to go to a mechanic. I have free towing up to 21kms in diameter from my house. I want to take it to someone that isn't Holden to fix it. They said all plugs are in, no fault codes read and the timing chain is fine. It started and the guy said it sounds like I am getting firing out of the upper inlet manifold.
    Fingers crossed it is only a cheap fix.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    IN the engine? Or the belts maybe?
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    ok be very specific here, what did you mate touch/remove/move/unplug?
    Silver Certified.
  15. #15
    VY SS
    May 2011
    Auckland
    I think it probably has a vac leak and the noise is probably a belt.
    Will it idle on its own? Ie Will it continue to idle if you take your foot off the gas?
    Can you get it to continue to idle using the gas pedal?
    Check for sanity sake that your oil is at the full level and your not running ridiculously low oil.
  16. #16
    VE Omega
    Nov 2009
    Here
    Quote Originally Posted by StoneX View Post
    I am not sure exactly but sounds like the engine and not a belt. And at the top of the engine and/or front
    Throttle plug on right side of throttle and MAF plug, both were put back on.
    Heaps of oil. Was replaced with Penrite fully synthetic oil and oil filter replaced. Fuel level is about 33% and coolant is about 75%
    I have to give it huge amounts of pedal just to get it to actually tick over, and when I do is when it makes that horribly loud noise and idles for about 10 seconds with my foot on the pedal, chokes and dies.
  17. #17
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Why did he need to remove those plugs? Did he attempt to clean the throttle body?
    Silver Certified.
  18. #18
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    Can u reset the ecu and try start it?
    how to reset ve commodore sv6 ecu?
    yup! I think I might actually be gay
  19. #19
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    I dont think you can reset a VE ECM by simply disconnecting power from the ECM as it uses EPROM which retains data even when power supply is removed.
    Silver Certified.
  20. #20
    VE Omega
    Nov 2009
    Here
    We were going to take the upper inlet manifold off to change the plugs but didn't bother doing it.
  21. #21
    VE Omega
    Nov 2009
    Here
    I took my car into APC at Underwood today, they had the car since about 12:30 and by 5 they still had no idea what it was. They said they will call me tomorrow... Not good ay. They said my timing chan can stretch and that is a possibility. Anyway tomorrow it seems I will know. Damn it this is not going to be cheap.
  22. #22
    ve ss
    Nov 2010
    Darch WA
    sorry to hear that mate.hope all goes well with the repair:-)
    Hazy 64
  23. #23
    VE Omega
    Nov 2009
    Here
    Quote Originally Posted by glennho View Post
    Thanks, so do I.
  24. #24
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    You sure your mate didnt unplug any of the plugs off the back of the inlet manifold, or knock any vac lines loose and the squeeling you're hearing isnt a vac leak?
    Also, what is the battery voltage?
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
  25. #25
    VE Omega
    Nov 2009
    Here
    Quote Originally Posted by Sabbath' View Post
    To be honest mate I don't know, I only seen him unplug the 2. The noise that I am hearing I have never heard before.
LinkBacks (?)
  1. 19-03-2012, 08:38 PM
  1. New Key now car wont start and cuts out when km's on cluster start flashing :(
    By rowiejoan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2011, 10:44 PM
  2. odometre stop start stop start???
    By The pig in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-07-2011, 06:35 PM
  3. vs calais wont start unless i kit unlock before i start
    By scottmcguinness172 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2011, 06:40 PM
  4. Wouldn't start when warm, now won't start at all
    By karwalski in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-05-2010, 06:18 PM
  5. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
