Results 1 to 10 of 10
Thread: Check oil light after oil change
    fcm
    fcm is offline
    VE Commodore
    Jan 2012
    Default Check oil light after oil change
    G'day , I own a 2006 VE Commodore series 1. Changed the oil yesterday putting in roughly 6.5l of penrite HPR5 and changed the filter. I also done an oil flush. I have the cartridge filter that sits in the metal cannister which i filled with some oil before filling through the oil hole. Today im driving and get the check oil light. the 3 hole dipstick is just above the 2nd hole. Whats the drama ? What should i do ?
    Cheers.
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    well for a start ve alloytecs hold approx 7 litres.
    did the light come on straight away? and by oil flush do you mean engine oil flushing additive was used before you drained the oil?
    fcm
    fcm is offline
    VE Commodore
    Jan 2012
    The light came on three times the day after. You are correct about the flush. I added it to the oil ran it for 15 minutes then drained the lot.
    Cheers.
    Boonz's Avatar
    Jul 2005
    How many k's has your car done? Could of dislodged some carbon from the heads an its blocking the oil pickup
    Sent from my MB860 using Tapatalk
    fcm
    fcm is offline
    VE Commodore
    Jan 2012
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by Boonz View Post
    Early VE V6 only hold about 6.7litres.
    Do you mean the red oil can light? Generally means low oil pressure. If its a bit sludged the engine flush has probably dislodged some sludge and its partially blocking the pickup as said above.
    Silver Certified.
    calais06's Avatar
    calais06 is offline Donating Member
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    My early alloytec is full at around 6.9L I oil.. (just above the 2L line on the second bottle of oil left).
    vx custom 600RR
    Oct 2010
    if you recently bought i'd guess oil changes where not done on a regular basis
    i've seen this on engines with 100K full of sludge
    fcm
    fcm is offline
    VE Commodore
    Jan 2012
    OK, so how do i get rid of the sludge ??
    The check oil light didn't come on again after lunchtime yesterday despite driving the car.
    Is it safe to drive ?
    Cheers.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    How did the filter look when you pulled it out?
    When you put new oil in does it get dirty pretty much straight away or does it look clean after running the engine?
    It should be safe to drive if the oil light isnt on and the engine isnt making any abnormal noises.
    Silver Certified.
LinkBacks (?)
  1. 13-02-2012, 10:39 AM
  1. Check engine light after plug change
    By holdenvtman1123 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-08-2011, 09:54 PM
  2. Change or check fuses or rear lights
    By nicarena in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-09-2010, 06:51 PM
  3. check Tail Light dash light on
    By egadgetjnr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2009, 11:43 PM
  4. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  5. Check Thermostat and Coolant Change
    By TigerVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-07-2006, 11:58 PM
