Results 1 to 6 of 6
Thread: installing aeroforce gauges
    mjg
    mjg is offline
    VE SS
    Oct 2009
    Default installing aeroforce gauges
    Hey all,
    I've searched but couldn't find what i was looking for.
    Im awaiting a set of Aeroforce Interceptor (twin) gauges which ill be installing into my 2008 VE SS. They will be mounted in an SS Inductions holder.
    now my question is, (before i start pulling the dash apart), what is the easiest/best way to run the cable from the gauges to the obd port?
    if anyone has pictures or has a similar setup and can share some insight, that would be great.
    Thanks,
    Mick
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    Once you have the centre part of the dash removed running the wires is pretty straight forward, this is my car.
    You can see that there's plenty of room to run wires, but i found it a very easy install because mine came in kit form with a wiring loom. Does yours have a loom or are you wiring from scratch?
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    kits come with a obdII port connector....electrical tape (coat hanger may help)around the wires and pull through the dash not hard when its all apart
    EASY $30 DIY Cold Air Induction!
    Quote Originally Posted by stuffedifiknow View Post
    would this mod work like forced induction.
    mjg
    mjg is offline
    VE SS
    Oct 2009
    Yeah it's just a cable connecting both gauges which then has a plug for the obd port. I was thinking the old coat hanger and duct tape trick. Will have to give it a crack and let you know.
    Big_Simmo's Avatar
    Big_Simmo is offline Great White Cranberry
    WM 6L Stateman
    Apr 2010
    Nov 2005
    Warrnambool
    Quote Originally Posted by Big_Simmo View Post
    Where did you find your kit that you threw in your calais??
    JHP. A bit pricey but well worth it if you want the quality.
  1. Aeroforce Scan Gauges - Group Buy
    By bonners in forum General
    Last Post: 15-10-2011, 06:47 AM
  2. Aeroforce Gauges in V6 VY
    By a1k3m1 in forum General Discussion
    Last Post: 09-11-2010, 04:44 PM
  3. Installing Gauges
    By dave88_88 in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-07-2010, 01:15 PM
  4. Installing gauges?
    By Silver surfer in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-11-2007, 09:58 AM
  5. Installing gauges?
    By Silver surfer in forum Electrical Wiring / Questions
    Last Post: 28-11-2007, 05:46 PM
