Hey, I have 2008 VE SSV with 105000km, and my AC has stopped blowing cold air. just wondering if anyone else has had to had their ac regassed with this many ks on the clock.
Check the belt hasn't come off. If it hasn't it may need a regas
This recently haappened to my calais v and it had only done 70000km,the ac belt was disloaded and it cost me about 800 to fix it apprantly it is a common problem with the l98.
If its thrown a belt theres a new bracket they fit with the new belt to prevent it coming off again. They may also recommend doing the harmonic balancer as they are usually part of the cause if they have a lot of runout.
Silver Certified.
thanks gents, I popped the bonnet and the belt has come off. wasn't fun driving home from work in 36degree heat today.
Will it only come off if you really push the car while the ac is on?
It's best to fix the cause of the problem than to try and work around it.
Originally Posted by Reaper:
Originally Posted by Jecs:
Mine threw the belt every time I booted the car hard... Got a new one and it was off within an hour... Got the revised bracket and belt and it hasn't come off since.
Anyone had problems with spitting off air-con belts on 6.0Ltr motors?
2006 SSV manual - A/C belt keeps spitting off
why i ask is i have never had it come off before, always turn ac off when going hard. but i took the car to have new tyres put on and it came back with the ac not working (at least i think it did) so i wonder if the guys at tyre power took it for a fang.
I have been meaning to change the bracket on mine for quite some time.
Mine came off once a couple of months ago, and hasn't come off since....
(Original belt and bracket)....
But every car and situation is different.
Mine has done around 113000Kms
At least you now know what to look for if it happens again.
Best bet is to pop in to Holden, and grab a new belt / bracket whenever it is convenient, and then look at changing it either,
1) When it happens again, or
2) In the winter time Lol....
you need to see if it has gas mate, perhaps check the fuses aswell incase of an electrical issue
He already worked out the belt had come off![]()
Silver Certified.
