Results 1 to 17 of 17
Like Tree6Likes
  • 2 Post By wingwang99
  • 3 Post By Munz
  • 1 Post By vicarious
Thread: Commodore Water Depth/s
    Holden VE II SV6 Ute Manual (Poison Ivy) 2011
    Apr 2011
    Aramac, Qld
    Default Commodore Water Depth/s
    Hi Guys,
    Just wanting to know how much water can a VE can take, I own an Series 2 SV6 Ute.????
    Where is the Air Intake actually enter the system also..
    Thanks Alot...
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    2010 Voodoo Sv6
    Sep 2008
    Maybe do a practical test, keep pouring water into the intake manifold until a piston comes through the head. Remember to put your safety glasses on though...
    Quote Originally Posted by Cousin Slow Poke View Post
    Stick a gerbil in your pants!
    VE SS series 2
    Aug 2011
    Orange
    The smallest amount of water will cause hydraulic lock and will pretty much put a hole in your engine block. That goes for any engine especially diesels. I don't know why your putting a commodore near water anyway? And the intake picks up down near the fog light.
    VE SS series 2
    Aug 2011
    Orange
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Quote Originally Posted by Mitch-VE6LTR View Post
    behind the headlight perhaps
    EASY $30 DIY Cold Air Induction!
    Quote Originally Posted by stuffedifiknow View Post
    would this mod work like forced induction.
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by Munz View Post
    It's actually a bit under the headlight. Not right down by the foglight but it is lower than the headlight.
    So the answer is, anything that's higher than the bottom of the front bar and you could potentially risk damage to the motor.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    VY SS
    May 2011
    Auckland
    If your taking it in water just remove the pipe off the airbox going down into the bumper and add one that faces backwards into the engine bay.
    I'd love to see a commy with a snorkel.
    Apr 2011
    Aramac, Qld
    Hey Thanks Guys,
    Yeah I was only planning on going through 0.3m preferabable less.. And yeah i was planning to undo my Air Cleaner.
    Wont need to go through anymore,
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    I can't see how 300mm would cause too many issues. Just remember, If you look like getting in the shit te easiest way toget out is a whole heap of flooring (a la Homer).
    VE2 SV6 SPORTWAGON
    Feb 2006
    SA
    Quote Originally Posted by Troy711 View Post
    until some knob comes the other way flat knackers and then you get a nice bow wave over the bonnet
    The Mad Dutchman
    Mike08's Avatar
    Mike08 is offline No Back seat drivers
    VE SS Ute
    Feb 2009
    Queensland
    There is no way in hell i would be running a VE SV6 through 0.3. Water getting in and around the bottom half of your engine is not the only concern to be worried about here.
    Is it running water , still water, how many wankers are coming through towards you. Is your car lowered ?
    0.3 is more water than what it appears.
    Cheers mate.
    Mike
    07 VE CALAIS V - V6
    Mar 2011
    Illawarra NSW
    Quote Originally Posted by vicarious View Post
    exatcly what happened to my mate when his wife drove his vz calais through a flooded road early last year. she reckons it was only about a foot deep and had to drive through it to get home. 4wd came the other way and bow wave went up over bonnet and car stalled and never started again. open door and small amount of water flowed into cabin so wasnt that deep. end result was calais "written off" as water got through motor, sensors and gearbox elects. as its the same gearbox and allloytec as the ve I would say keep your "feet" dry at all costs.
    VY SS
    May 2011
    Auckland
    Friend of mines old man did this too. Went under a bridge in a vu ss ute through a quite deep puddle.
    Hydrauliced the engine and stuffed the manual box. (engine stopped and wheels kept on driving). That was a write off too, although insurance payed.
  15. #15
    Ve ss
    Jan 2012
    Nt
    Been though 0.3 in a 2007 ss. No problem just turn the AC off. Also been pulled through 0.5-0.6 car off no water in the air box. I have pics but I'll have to work out how to post from phone. Ok can't work out how so stuff it not good pics anyway
  16. #16
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    I've done it in older commos and never had an issue, even an ecotec, but the newer ones make me nervous. Still, i bet there's been plenty of VE's go through a foot of water around the country and most probably survive. if you have to do it just do a steady speed maybe 20 kays and keep going till you get across or it goes bang. and walk it first if there aint any crocs.
  17. #17
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Last time we had minor flooding our workshop was full of VEs with munched engines due to swallowing water.
    Silver Certified.
  1. Tyre tread depth
    By Snowfox in forum General
    Last Post: 29-09-2011, 10:35 PM
  2. Depth of stereo DIN
    By JD1337 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-05-2009, 05:28 PM
  3. Front mounting depth for VP
    By arrow224 in forum Car Audio
    Last Post: 05-05-2008, 09:59 AM
  4. Door speaker depth GTO
    By Swinghammer in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-12-2006, 07:25 AM
  5. Some in depth questions, need help.
    By Stubby in forum Car Audio
    Last Post: 02-07-2005, 11:05 PM
