Results 1 to 25 of 25
Like Tree2Likes
  • 1 Post By RiCeY
  • 1 Post By RiCeY
Thread: ve key pad not working
    ve sv6
    Aug 2010
    Default ve key pad not working
    hey guys, my daughter decided she didnt like the way my son was looking at my car keys and hid them in her car seat and we couldnt find them so i resorted to my spare set and the key pad for the door looks and boot release would not work but could start the car ok. im not sure if the battery has gone flat or it wasnt programed corectly when i had a new flip key programed. what do you think it could be, just as simple as a flat battery or another problem. if battery is it easy to replace.
    Ghost's Avatar
    Ghost is offline Donating Member
    Vr Commodore Executive 1993
    Sep 2011
    Adelong New South Wales
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Did they have your spare key when they programmed the new key?
    Silver Certified.
    ve sv6
    Aug 2010
    yes, they needed the second key to do it they told me, so i bought in both keys to reprogram.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Ghost's Avatar
    Sep 2011
    Providing they have changed a Holden key setup I'll have to pay 150 just for one for my vr because the remote case is sealed
    Ghost's Avatar
    Sep 2011
    ve sv6
    Aug 2010
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    The batteries are changeable in VE keys and lol at 20 year battery life HAHAHAHAHHAHAHAHAHHAHAHHAHAHAHAHAHHAHAHAHAHHA
    Heath I doubt you have a clue as every 45,000kms a new remote battery is part of the service.
    Silver Certified.
    Ghost's Avatar
    Sep 2011
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Yet you cant change the battery in a key and believe in fantasy batteries that last for 20 years?
    Silver Certified.
    e3 clubsport r8 m6
    Nov 2011
    This might be a bit off topic but what happens to the battery in my spare key I am assumming it will still go flat overtime eventough it doesn't get any use?
    Also is there any chance of the batt leaking and stuffing up your key?
    Ghost's Avatar
    Sep 2011
    Well the least amount of presses for a car remote is 4 times a day also the battery is a 12v battery where as a tv remote is only 3 volt and how many times a day does that get pressed and as far as not being able to change a battery blame Holden for soldering it to the remote
    Ghost's Avatar
    Sep 2011
    Depends on the battery if it's a flat round one they are pretty well sealed unroll contact with water and the little one that looks like a short aaa battery can corrode if it sits and never gets used I switch out my keys every 6 months so they aren't just sitting around
  15. #15
    Ve r8 , VL turbo
    Oct 2011
    Camden
    Quote Originally Posted by heathsydm View Post
    Mine would be lucky to be pressed twice a fortnight....
    I did change the battery in mine as per holdens recommendations at the service. If Holden have reprogrammed your keys then they should be able to check the program on it matches
  16. #16
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Batteries will eventually go flat over time even if not used. They shouldnt leak no.
    Cant compare a car remote to a tv remote. A car remote signal has to be much stronger to travel further distances and pass through the exterior of the car. Secondly the VE batteries are 3 volt and most tv remotes have 2 x 1.5 volt batteries.
    Silver Certified.
  17. #17
    e3 clubsport r8 m6
    Nov 2011
    Thanks will have to look at which battery is in mine... You wouldn't happen to know which battery I have? my key fob is e3 Clubby but I am pretty sure they are same as the commodore flip out keys
  18. #18
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
  19. #19
    e3 clubsport r8 m6
    Nov 2011
    Quote Originally Posted by RiCeY View Post
    Thats what I thought
    Thanks RiCeY
  20. #20
    ve sv6
    Aug 2010
    ricey, is the battery something i can change my self or is it a holden job?
  21. #21
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
  22. #22
    ve sv6
    Aug 2010
  23. #23
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
  24. #24
    07 VE CALAIS V - V6
    Mar 2011
    Illawarra NSW
    VEs have the flat round battery.
    yep its a CR2032 i think
  25. #25
    ve sv6
    Aug 2010
    thanks womble.
  1. thermo fan working..but not working!
    By nalchlan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2011, 12:19 AM
  2. ac not working
    By lion_g in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-03-2011, 10:18 PM
  3. Replies: 2
    Last Post: 07-10-2009, 02:40 PM
  4. traction control light on dash not working... except for the fact that it is working
    By redcv6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2009, 10:41 AM
  5. Fan not working on VN
    By modcon in forum Site Feedback / Site Problems
    Last Post: 06-04-2006, 04:59 PM
