hi all,
just noticed yesterday and this morning my car has started to make a "flutter" noise when starting up.
i do not ever recall noticing this before now. could it be an exhaust leak?
sounds like its coming from underneath the drivers seat, listening from inside the cab.
any ideas?
Baffle might be loose,
Is this it?
Could be the gasket between the Y pipe and the cats.
What exhaust has it got?
stock headers, stock cats, Perry 2.5 inch cat back. (never heard of perry, last owner had this fitted)
Perry has been bought by HM but they were a big sports exhaust company in the 90's in their own right.
Get under it with a piece of hose used as a stethoscope and run it around the joins to see if any are leaking. You will hear it through the hose quite distinctly.
alright, thanks for the tip.
ill have a look underneath tonight after work and post back with my results.
cheers!
I had the same problem with my SS, when ever i started it, you could hear a flutter noise, while idleing, you could rev the car, and hold it at approx 2500 revs, and then the noise would be constant until you relese the revs. If i was driving slow, stopping, starting etc... you could also hear the noise when the car was changing back to first gear, it would flutter for a few seconds and then be fine. The noise started and after time gradually got louder. Anyways i took it to holden and my cat converter had shat itself. Replaced under warranty.That was my experience anyways. Hope this helps : )
i have the same problem with the left side exhaust on my ss,will check the cat out.
Hazy 64
Throw some talc powder on the joins will be obvious if its leaking.
Silver Certified.
