Page 1 of 2 12 LastLast
Results 1 to 25 of 47
Like Tree12Likes
Thread: Coin tray
    Sep 2004
    Default Coin tray
    Hi all,
    Just wanting to know, is it possible to fit the coin tray flip lid thing that the Calais has into a an Omega/Equipe?
    Reason I ask is, in my VZ, I used to store all my change in the little holder inside the centre console, but they've done away with that. The little coin holders don't exactly suffice, so I want to chuck my change in the front part, but would rather it be covered, so it's not visible to any unsavoury types.
    If it can be fitted, does anyone know that part# or what it's actually called, so a wrecker doesn't look at me stupidly?
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Pretty sure it would fit in place of the tray but not 100% as Ive never tried it. Just say the compartment below the radio facia.
    Will need to remove the trim that covers the gear stick to do the changeover.
    Silver Certified.
    Jonah 101's Avatar
    Jonah 101 is offline I love photoshoppin
    vs executive Manual
    Jan 2012
    Tauranga
    Do you have an ash tray?
    My ride-VS commo, Just finishing the manual conversion. Working out those annoying bits!
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    No I have a VZ but Ive pulled the VE consoles apart many times and Im pretty sure the tray and compartment would be interchangeable.
    Silver Certified.
    Jonah 101's Avatar
    vs executive Manual
    Jan 2012
    Tauranga
    Yeh I thought it wouldnt be pc to put an ash tray in cars anymore.
    VE Omega
    Nov 2010
    I'm saying a definite maybe. I just checked out a Caprice for you and I think you would only need two bits because the flip cover is attached to the mechanism and the tray. The other thing you will need is the rubber insert thing. Send a message to your local dealer and get a price for them, I think it should probably work.
    Oh and RiCeY is correct the gear stick plastic will need pulling off, just get your fingers under it and pull/wiggle.
    Check out my VE Commodore My Omega Mods
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    I think they are different trays because the one with the lid has the hinge intergrated into it from memory.... might be wrong Ill have a look tomorrow if I remember and get part numbers.
    Silver Certified.
    VE Omega
    Nov 2010
    Correct different trays, the hinge takes up a decent amount of room.
    Sep 2004
    Yep, I know the tray is smaller to allow for the hinges, was hoping I could just buy the whole unit. Hopefully I can find one to match my trim.
    I will give the dealer a call and see what the price is :-)
    Oh and to the ash tray, nope, no ash trays in my last two Commodores (VZ and now the VE). I believe you can purchase a 'smokers' kit which gives you a cigarette lighter and a small ashtray that goes in the same spot though.
    Quote Originally Posted by RiCeY View Post
    If you could get a part# and price that would be awesome :-)
    dmacey's Avatar
    dmacey is offline Think about it,
    SSV Series II Sedan Manual
    Sep 2011
    Im keen for one also, So part number would be awesome. Will it match the trim colour in a SSV?
    Is this it?
    Sep 2004
    Dropped by my local Holden dealer today, the guy was very helpful. He ordered the part in but they put the wrong part in the box, it was just the plastic bottom of the compartment. After having a chat, he found out that the mechanism comes separate and then you choose your lid colour, so anyone looking to buy this should be fine finding the right colour to match their trim.
    He said the list price on the system is about $40, but not sure if that was for the whole lot, or just the mechanism. He's getting the correct part shipped tomorrow, so we'll say. Anything under $100 and I'm happy to pay it (since it's going to save me $300 if my window gets smashed by someone wanting to steal my change).
    Johnsy's Avatar
    Johnsy is offline ★★★★★
    HSV R8 LS3
    Oct 2005
    C/Town
    Sep 2004
    Alright, followup for this.
    Finally got the correct part. Now, it comes in two parts, the mechanism/tray and the fascia. The fascia apparently only comes in two colours, Rado Grey (gunmetal grey) and silver, luckily the rado grey is the perfect fit for the Equipe.
    Part numbers and descriptions are:
    Mechanism - VE Front Storage Comp Assy - Unpainted P&A - Part# 92200591
    Fascia - VE Front Stor Compt Facia Rado Silver - Part# 92170909 (sorry, I don't have the silver part#
    Installation was a piece of cake, you just pop off the fascia trim around the gear stick, either with a trim tool, or as I did, using a knife in a soft cloth. Work backwards from near the cup holders and pry it off. You don't need to disconnect any cables. Pull the fascia back a bit, remove the two screws holding the existing tray in, then just pull it forward, it's just got push clips at the back.
    Then, basically the reverse but with the mechanism.
    NB. You need to put the mechanism in BEFORE putting the colour fascia plate on. I tried about 5 times and it just wouldn't fit for some reason. Took the fascia plate off, put it in, screwed it down and then put it on and it worked a treat.
    No before picture, but here is what it will look like before:
    http://www.autopartshop.com.au/images/P/654576.jpg
    And After:
    http://www.anyauto.com.au/wp-content...SEATS-DASH.gif
    http://www.caradvice.com.au/wp-conte...-3-625x426.jpg
    Now my coinage can be out of sight. If anyone wants a picture of my actual install or if you live in Perth, I'd be happy to assist.
    Oh, and total price? $59.
    Other notes:
    VE Commodore Sportswagon Equipe Series II
    VE Omega
    Nov 2010
  15. #15
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    From memory if you pull the radio facia off you can fit the tray fully assembled.
    Silver Certified.
  16. #16
    Sep 2004
    I tried to take the car apart as little as possible. It was pretty easy to put the fascia on when the unit was installed, it just clips over a little lip, then clips up the top.
    The only 'issue' I've found is that the colour doesn't match the trim around the gear stick, only the trim on the stereo. I suspect that the other colour matches the trim around the gear stick, so they've used two different colour trims in the Equipe. If you have a look at dashboard photos online, you'll see that in the Calais, it's the darker colour everywhere, and in the Berlina, its the silver colour everywhere.
  17. #17
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    The radio facia literally just pulls off in a second or two
    Silver Certified.
  18. #18
    07 VE
    Dec 2008
    SA
  19. #19
    Sep 2004
    Quote Originally Posted by Matt_27 View Post
    Presume series 1 would use the same part numbers. Looks the same size?
    I don't believe so, I think the Series 2 has an additional little plastic lip under the stereo that the Series 1 doesn't have, I could be wrong though.
  20. #20
    07 VE
    Dec 2008
    SA
  21. #21
    2010 VE SSV ute XYZ XYZ
    Jun 2011
    Will the dark colour match the SSV onyx interior - series 1? Hard to tell from the photos
  22. #22
    VE SV6 Thunder Ute
    Jan 2012
    One thing i don't like about the Series II Equipe, looks like Series I dash
    Some people lie so much they begin to believe there own bullshit.
  23. #23
    VE BERLINA
    Feb 2010
    HI I HAD A BERLINA WITH THE PART YOU ARE TALKING ABOUT YOU CAN BUY FROM HOLDEN NOT SURE ON PRICE I TOOK MINE OUT AND BOUGHT A SMOKERS PACK $123 USED THE FRONT ONE AS I HAD GAS INSTALLED USED THE CIG LIGHTER HOLE TO MOUNT THE GAS GUAGE AND OUT OF SIGHT SOLD THE REAR ASH TRAY ON EBAY GOT HALF MY MONEY BACK, I WOULD THINK HOLDEN WOULD BEE AROUND $50 and the one i took out ebay again sold for around $58 so not too bad
  24. #24
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    Quote Originally Posted by donthree View Post
    Capslock and basic punctuation make it a hell of lot easier to read posts mate.
  25. #25
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Why's he yelling?
    Silver Certified.
  1. How much coin ?
    By patrolking in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-08-2011, 07:17 PM
  2. coin help
    By vp ss in forum The Pub
    Last Post: 09-08-2010, 10:01 PM
  3. The Last Coin
    By Damo304 in forum Jokes/Humour
    Last Post: 23-09-2009, 11:50 PM
  4. deck into vs coin tray under security led
    By crainy in forum Car Audio
    Last Post: 26-10-2005, 06:04 AM
