Results 1 to 13 of 13
Like Tree2Likes
  • 2 Post By Boonz
Thread: Strange vibration at 90-100kms - Transmission or Driveshaft ?? Opinions please
    VE Calais V
    Jun 2006
    Christchurch
    Default Strange vibration at 90-100kms - Transmission or Driveshaft ?? Opinions please
    Hi Guys, I have noticed what I think might be a drive shaft vibration in my Calais over the past few days.
    I notice it only when using the tip-tronic changes & only in 4th & only bewteen 90-100 kms per hour.
    The more torgue load you put on, the more it seems to build a harmonic vibration & if I button off it stops.
    I have heard people talking about replacing their drive shaft bearings or something similar.
    I wonder if it might be that or something going on in the transmission ???
    Any ideas or opinions welcome.
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    theres a techline out to fix that problem
    CONDITION
    A driveline vibration may be felt at 80-105 km/h. This condition may occur regardless of the gear selected. Technicians can diagnose the condition by unlocking the torque convertor using Tech 2 and the vibration will still be evident.
    This is not to be confused with any other driveline boom or drone at any other vehicle speed.
    CAUSE
    The propshaft, rear coupling and differential pinion flange may be aligned to create a minor overall level of imbalance. This can be great enough to cause a resonant frequency in the rear sub-frame.
    CORRECTION – Vehicles in Production
    Vehicles have been fitted with lower tolerance rear couplings from MY10 VE & WM production.
    CORRECTION – Vehicles in Service
    Summary: After verifying that vehicle has the condition as described above, replace the rear coupling assembly and mandatory replacement bolts.
    Replace the rear coupling assembly, ensuring a NEW fastener kit for the propshaft to coupling joint is used –
    VE Calais V
    Jun 2006
    Christchurch
    Thanks for the response Boonz. Certainly seems to fit my situation. I will get the coupling looked at.
    2010 ve sv6 ute
    Jan 2012
    victoria
    How much would it cost to fix? Dad was driving my ve the other day and said in the rear end sounded like a voooo voooo like a flat spot sound
    VE Calais V
    Jun 2006
    Christchurch
    2010 ve sv6 ute
    Jan 2012
    victoria
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by velj View Post
    Could be a wheel bearing making that noise.
    Silver Certified.
    VE Calais V
    Jun 2006
    Christchurch
    VE Calais V
    Jun 2006
    Christchurch
    Ok here's an update on my vibration. Have had the front & rear driveshaft couplings checked & they seem ok.
    There is however small amounts of sprayed oil residue around centre bearing though ?
    The vibration definately seems speed related & only under load.
    It is not restricted to 4th gear when using tiptronic as I thought, but does it in auto & in other gears too.
    I suspect the centre bearing may be the culprit but I am still not convinced the wheel bearing/s aren't involved yet.
    I am inclined to replace the centre bearing first & see what the result is.
    I will update you then.
    VE Calais V
    Jan 2012
    other common thing which i had done on mine recently is the torque converter lockup on the calais/sv6 5 speed can often be reason. So may also be worth taking to local auto transmission specialist. if just torque converter replacement and trans service - about 900 bucks including GST.
    VE Calais V
    Jun 2006
    Christchurch
    calais06's Avatar
    calais06 is offline Donating Member
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    Quote Originally Posted by cal-ay View Post
    That sounds like an issue I have with mine sometimes when going down a mountain if I use tip-tronic and then put it back into auto, it will drop the gear down and wont shift up until u rev past like 4000rpm
    VE Calais V
    Jun 2006
    Christchurch
    Hi guys, been a while tracking this vibration down. Wasn't anything we discussed at all.
    I had the mechanics check all the things suggested in previous posts to no avail. Still did it.
    I kept listening to the noise until I pinned it down to the left rear.
    The wheel bearings had been checked so I started thinking half shaft universals etc, till my friend said lets have a look ourselves.
    So we had a look at everything including a close inspection of the tyres & sure enough the very inside edge of the L/R tyre was bumpy & uneven as you felt around it.
    I couldn't believe it after all that time & effort for it to be a delaminated tyre. How basic & how did everyone miss that I thought.
    Oh well new tyre fitted, FOR FREE almost a year after purchase, from our local Mag & Turbo outlet. Great guys, wouldn't let me pay even though I was happy to.
    After being told that a transmission replacement was on the cards I can tell you I was well pleased to get that problem sorted out.
    Thanks for all the help guys.
LinkBacks (?)
  1. 20-02-2012, 08:44 PM
  1. Replies: 12
    Last Post: 20-04-2011, 07:12 PM
  2. Transmission Vibration
    By ss_0195 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-03-2011, 10:29 PM
  3. VR strange bad vibration
    By rob_rob in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-09-2009, 07:21 PM
  4. Transmission Vibration? M6
    By JMiller in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-06-2006, 12:03 AM
  5. auto transmission vibration in vc
    By marky mark in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-10-2004, 10:19 PM
