Hey guys, had my car fixed under warranty on Tuesday due to the fuel gauge not working AGAIN. Anyways all is good with the fuel gauge, but this morning I could smell fuel when I was driving, i hadnt smelt it before. Got home and could still smell it. I didnt think anything of it as I had just re fueled and thought I may have spilt some on the side of the car or on myself. Wasnt until I drove the car later on and noticed a "wet" patch on the ground when i reversed, turned out it was fuel. I jacked the car up and yep, leaking fuel from somewhere around the fuel tank.It only leaks when the car is running. Its leaking from a non visible part of the tank as its running down the side and dripping onto the ground. Maybe the guys at holden didnt put it back correctly?But i just found it weird that it only started leaking today. They should fix it yeah? Is it safe to drive the car still? Cheers guys : )
Id get it towed back at their expense. Sounds like one of the hoses from/to the fuel pump is leaking or the O-ring isnt fitted properly.
I wouldnt drive a car leaking fuel, no.
Silver Certified.
yeah as said dont drive the car,get it towed back to get fixed properly:-)
Hazy 64
make sure you rip them a new one while you are at it for placing your safety at risk...... oh and ask them to get a tradesman to do the job.... a lot of Holden dealers have a habit of using cheaper apprentice labour to do the work on cars..... it's the reason mine doesn't go to a dealer any more.
Reviled did i live as evil i did deliveR
- UNDERSTEER is when you hit the wall with the front of the car.
- OVERSTEER is when you hit the wall with the rear.
- HORSEPOWER is how fast you hit the wall.
- TORQUE is how far you take the wall with you.
