Results 1 to 10 of 10
Thread: Ve sv6 with hsv head unit
    2010 ve sv6 ute
    Jan 2012
    victoria
    Default Ve sv6 with hsv head unit
    Hi everyone I current just got a 2010 ve sv6 sidi and really want to put in a Holden iq system I can source one through a friend what I want to no is would it fit and would it just be plug and play it has all the air con Controls and the binnacle gauges it's from a 2010 hsv ve e3 maloo
    Thanks
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Plug and play I doubt as its a completely different system so the other modules that normally communicate with the radio ( HVAC for instance) wont recognise the IQ system.
    Silver Certified.
    VE Calais V 6.0L
    Aug 2011
    I have NFI about the Series II - E3 Holden IQ stuff...
    But for Series I stuff, you need to set the VIN number for the radio module.....
    The problem with the Series II stuff at the moment is
    1) There is noworkshop manual available to the "Public" (If you know what I mean)...
    2) The gear is prohibitively expensive to buy and attempt to hack...
    So to try and answer your question,
    Will it physically fit ??? Yes, it should.. I dont know if different trim peices need to be sourced ?
    Will the wiring connectors be the same ??? - Could be, hard to know for sure unless someone takes some photos of different model wiring connectors.
    Will it require programming ??? - Definitely !!!!! This is the only thing that I can be certain of at this point....
    I kinda hope this helps....
    Let us know if you proceed down this path, as a couple of us are working on Series I Radio/HVAC programming via EEPROM hacking, and have a fair bit of it nutted out,
    and we might be able to offer some assistance..
    Matti
    2010 ve sv6 ute
    Jan 2012
    victoria
    Thanks mate. Well in that case I might ring up Holden see what they say and if not il leave it until someone has done it or sure, dot have the money ATM to be trial and erroring haha thanks guys
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Holden probably wont have the answer as its not something we would do to know if it works or not.
    Silver Certified.
    2010 ve sv6 ute
    Jan 2012
    victoria
    VE
    Mar 2011
    n
    Quote Originally Posted by velj View Post
    Thanks
    You can NOT install an "IQ" system in a series I VE. (FULL STOP)
    You are better off getting the HVAC & double DIN mod listed elsewhere on the board. This will allow you to fit a decent system...
    HIDs.....LEDs..... DRLs..... CHEV Badges..... ->
    VE Omega
    Nov 2010
    Hey mint just interested to hear why you say it can't be done?
    Check out my VE Commodore My Omega Mods
    VE
    Mar 2011
    n
    Quote Originally Posted by BigBoss View Post
    Because Holden in their infinite "wisdom" has designed the new system in such a way as it is not backward-compatible. If people could upgrade their series I instead of buying a new car, that would cost them, eh?...
    VE Calais V 6.0L
    Aug 2011
    Hi Mint,
    Obviously this is the case with Holden, as you said, there would be no reason to upgrade...
    Just wondering if you know exactly why it cannot be changed over ????
    Is it electrical plugs, programming, SW Can issues, physically wont fit ????
    Have you tried, or know of someone that has tried this ????
    I know of someone that has purchased one of these units, and will be looking at what is and isnt possible in regards to fitting to either Series II commodores, and possibly series I models.
    It would help greatly if someone can give a definitive guide as to why it wont work, or what needs to be sorted out to get it to work.
    I have seen a lot of posts on different forums saying certain things cant be done for the VE, and slowly slowly information is becoming public on how to overcome these limitations.
    (Example fitting HSV clusters to Non HSV models, programming Odo readings, Changing startup screens on colour LCD HVAC/Radios, fitting Pontiac G8 electrical stuff to Holdens, and vice versa)....
    Cheers for any help...
  1. VE Aftermarket Head Unit (fasica) Double DIN UNIT
    By forrest1992 in forum Car Audio
    Last Post: 01-06-2011, 12:46 AM
  2. New pioneer head unit - problems with old stock unit
    By thejdizzle015 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-07-2010, 05:19 PM
  3. Head unit running off head lights?
    By billyjim in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2010, 04:44 PM
  4. head lights cut out head unit.
    By Silver_VS_II in forum Electrical Wiring / Questions
    Last Post: 03-05-2010, 11:39 AM
  5. Replacing VT head unit with BT ipod unit
    By nickbedford in forum Car Audio
    Last Post: 23-06-2009, 03:00 PM
