8Likes
Hi we purchased a car off Brethren's which means no radio right?! Because of their religion. They removed the aerial, so I purchased a bee stub but still no signal at all. I figured that the previous owner hadn't realised that the car has 2 aerials. Supposably the rear window is an aerial as well. So I'm guessing the next step for them was to disconnect it somewhere. I tried at the base plate but It was near impossible, I tried the pillars to see if they clipped it as an easy fix. Nope not there.. Now the head unit, not much on the net about these little babies!! So I removed the plastic bits hiding the stereo near the steering wheel and there seems to be a plug disconnected with no lead to attach to the unit itself. Can someone tell me wether I'm hot or cold or is the aerial connect at the back of the unit? Which will be the next step of getting to! hopefully a pic comes up because I'm using tapatalk on iPhone![]()
Make sure the aerial is well earth too
My ride-VS commo, Just finishing the manual conversion. Working out those annoying bits!
Aerial plugs in on the passenger side of the radio.
May need to remove glovebox to access.
Silver Certified.
im having the same problem with my MY07 VE SV6 sedan.
The antenna cable plugs in to the head unit on the passenger side. It is a little white connector and plugs in to a gold plug.
Check out my VE Commodore My Omega Mods
Thanks guy I will go out in the garage and have a crack, I have started removing glovebox but go stuck on how to completely remove it to access this white connector on gold plug.
To remove the glovebox hit this link up, the glove box bit is about half way down.
Holden VE stereo removal instructions - udcaus
That is the plug
BTW that other plug in your photo is for the optional smokers lighter kit.
aahh mixed up religions, what's wrong with the off button on the radio, im assuming theres a fuse for the radio and thats been checked?
The Mad Dutchman
I don't think there is a fuse just for the radio... but i could be wrong.
Sorted fella's I got my hand in between the glove box and the stereo. Tight fit but it worked. Thanks Bigboss. Took awhile to screw in the amount of screws I removed trying to get somewhere of removing the head unit. Funny enough I did search the forums without much luck. Hopefully this will help some poor bugger who buys a VE off a bretho.
Hey Ricey you are also a champion mate, don't let anyone tell ya any different
All I want is to feel like Im loved.
Silver Certified.
Good 2 see people have a sense of humour on here, that's gold Ricey
Feelin the love![]()
Silver Certified.
Current Ride: 2011 VE Sedan - In Voodoo of course.
Last Ride: 2004 Subaru Liberty GT, Twin scroll turbo, tuned, Bilsteins, sway bars, no rice, 420Nm
Also Own: 1964 EH Wagon, modified interior, minor modifications outside
Now Im getting all emotional
Silver Certified.
