I have Bridgestone potenzas on my v8 and it barely spins in the wet.. But with traction Controll you wouldnt slip too much anyway, I can go full boot around a corner in the wet and it will not slide much or excessively spin..
Could not see how you'd loose controll
595s are no cheaper than the FK452s or KU31s, i went out and bought my last set as 595s after alot of people saying how great they were. They are not something i would recommend after driving on FK452s. When i need more ill be going back for the 452s.
I noticed the 595s to be noisy after about 5000 on them.
I haven't noticed a noise problem with my 595's but they are slippery in the wet, grip pretty well in the dry. I was going to go KU31 next but only one of my rear's was down (other was still more than 50% because it got replaced due to a screw) so I had to get another 595. I don't like how rounded the sidewall/shoulder of them looks compared to my front KU31's.
Hankook V12's are nice - I run them up front and have a fullrun/hero combo on the back.
GET a 175 v6 vz and you wll have no problems loosing traction.
what we have here,is a failure too communicate!!
I paid $240 a tyre for 452s, mainly because I didn't have the time to shop around - if you do, it's worth it. As said, you can pick them up cheap. I did get one quote for KU31s at $135 each in 245/45/18 - that is a bargain - they're a very good tyre. I had them before the 452s. They don't last that long thanks to the soft compound but they do grip well, wet or dry - and at that price, they're hard to go past. Having said that, the 452s are a step up again in terms of wet grip. I do find them significantly stickier in the wet than the OE bridgestones and, by the looks of things, they'll last longer. My OE tyres were done and dusted by 16-17,000km. KU31s made it to around 25,000km travelled - the 452s are sitting pretty on around 16,000 so far - well over 50% left at a glance, and they've probably had a harder life than the other sets so far.
Not sure - I've not had Federals but it sounds like it. Having said that, the 452s are holding up better than the KU31s I had but FEEL like a softer compound.
For the record, I wouldn't touch any other Falken tyre - have had a couple and they were all crap, which is why I was a little hesitant to try the 452s - but they really are excellent. All the other Falkens I've driven on have been very hard compounds, to the point of being treacherous. Similar story with the KU31s actually - they were the first kumho tyre I owned, but have since driven on a number of different ones, all of them have been rubbish - but the KU31s stick really nicely - they are a very soft compound - even the sidewall is a touch splashy, which is the only gripe I had about them - not much of a gripe though. Toyo is the same also - Proxes are fantastic - everything else is garbage. So you really can't buy with brand.
just do what i did and put some 20 by 275's on the back with bridgestone potenzas.
hahahhahah yet i still loose traction without clutch kicking![]()
Hey guys,
Had a spare few hours today so went in to a few shops and the guy from jax said these tyres were the go..
Anyone else had these? Any comments?
And just to add woohoo the triangles are gone!!!
hmmm i hope he didn't just say that because that was all he had in stock ? At least they have some trread depth on them
All i can say is tyres should be circles, not triangles.
I use the atr sports on my vr ss can't complain at all they are only 5000 km's old so time will tell
cheap is fine in my experience but triangles are just a fail. havent had to put tiers on my new ss yet.
VE (knock, knock, knock) SS Series 2 2.5" Stainless Exhaust, Pacemaker Tri Y Headers, VCM OTR, Custom Tune...
"Torque Is What Breaks Shit"
I find with triangles keeping them hot is the go. (drive em hard). mine one will be gone soon, threads at about .5mm. I think the fight in the car with the missues killed them![]()
My ride-VS commo, Just finishing the manual conversion. Working out those annoying bits!
I Had achillies ATR sports on mine. SSV, 245/35/20 and 275/30/20.
If you are going to do nothing other than drive sensibly on the street, they'll be fine. Anything more and you will quickly find they leave a bit to be desired. Falken 452's FTW.
Anyone tried these? ETyreStore - Welcome To The Revolution - ETyreStore.com.au - Home
Just as bad as triangles? Haha
Bridgestone Potenza's......... cost a fortune but damn good! $1600-2000 for 4 tyres....
I got RunFlatTechnology ones on my car..... came with it (ex-cop car). Damn good in the rain....... My SS drives virtually the same in the rain as the dry, virtually no slipping.....
2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
ive got a set of 235/45/17 gemstones on the vs, they grip well both wet and dry, alot better than the bald savas, and i run maddison 215/65/14 (never heard of them before) on my old girl, dry they're fine but damn do they slide in the wet, they were cheap when needed, even cut costs by fitting them myself, $120 all up, and they last, I just adjust my driving in the wet, so it don't slide or spin.
Gemstone, Ling Lang and Triangles, avoid completely
But value for money, you can't go past the khumos bridgestones firestone and toyo, for high profile stuff anyway. Bridgestone eager sf340s are the pick but you'll be lucky to find them I think they're discontinued.
Reviled did i live as evil i did deliveR
- UNDERSTEER is when you hit the wall with the front of the car.
- OVERSTEER is when you hit the wall with the rear.
- HORSEPOWER is how fast you hit the wall.
- TORQUE is how far you take the wall with you.
Seeing the topic is on tyres, I have a dozen 15 x 225 bob jane all rounders still brand new in my garage. I don't know what they will fit these days really, what would they be worth, if anything at all?
Aged Tyres
Doesnt matter if they new, how old are they? If more then 5 years old personally i wouldnt touch em.
VX SS - Monaro Themed - K&N Panel Filter, SS Inductions - (engine mods unknown) Mafless to be done
2.5" Exhaust, BSA 291 Chrome 19" wheels, KYB Shocks, Feroda Thermaquiet Pads, Slotted Rotors
Kenwood Head Unit, Clarion 6.5" Splits up front (soon), Clarion 6x9 Rears (soon)
Build Thread - EBAY Listings - Selling. Please check
yeah they are probably 3-4 years old, I might just chuck them! They take up spcae.
