hi everyone was reading my manual the other day and it says there is sports gauges so you can see oil temp bla bla bla, i sent thought everything and culdnt work out how to do it, could some one explain it to me if it is possible? cheers
Only if you have a ssv
maybe your mean "engineering mode" which is accessed by holding down the left scroll wheel on the steering wheel while turning the ignition on. this will display a menu in the center screen of your dash (not console/stereo). one of the options is oil temp plus others.
cheers womble il try tomorrow i only have a sv6 so il try haha cheers guys
Do you mean series I or Series II...
For Series I, SV6 and SS use a different Red LCD module.
It is this module that either displays the HVAC/Radio controls for SV6 and SS models.
For SS-V modules, the colour LCD screen shows the Radio/HVAC information, hence the different Red LCD module that is used to display the Oil and Battery information...
So in short, if you wanted this function, you would need to,
1) Upgrade to a colour LCD Radio/HVAC module,
2) Change the Red LCD module from an SV6 / SS to a SS-V module (Either twin or triple gauge),
Hope this helps
i have series 1
To have have the "sports gauge" you need to change the SIC module to the SSV sports type. Your currnet one can not be reprogramed by Holdens TECH2 to display the Volts/oil pressure.
If you change the module over you will not have radio and other information display like you have now. For radio and CD you can use the centre display on the instrument cluster but it is limited. You'd be flying blind a little. The price for a module is approx $340 rrp from Holden Parts. In the MY09 models they changed the display to a 3 window type which provides you with more information. See this link Post #38 I think.. VE SS V gauges youcan see the newer ones.
It would be better to convert the whole HVAC system to the SSV type however just so you know, the SSV facia plate (with LCD display) is $1,100....
You can go the eBay route for this stuff, which will be cheaper...
I got a 3 window type SIC module from eBay over a year ago for $120. I got it working (electrically) on a Calais V, but decided against using it, as there were too many trim peices to change,
(I have the cream interior, and the sports modules didnt come out with this colour).
The Colour HVAC/Radio modules go for around $400-$600, depending on condition, etc.
If you have an EEPROM programmer, you can program it yourself to work with your car. (Requires setting the VIN number).
You can also change the startup screen logo (Holden, HSV, Caprice, Chevrolet) and the text colour to match as well using this method.
This page,
www.carmodder.com • Programming the Colour LCD HVAC / Radio for the Holden VE Commodore
Describes what you need, the EEPROM programmer specs, as well as the EEPROM locations.
The EEPROM programmer and the 3M clip will cost you around $60 from eBay.
Hope this helps
cbz to much complicated shit, i saw one on ebay like a month ago if i knew this earlier i should ahve got it thanks guys
Hi,
Have a look at sport gauges on the ssv , this goes thru the basic process Holden need to do with a Tech2. I had my SV6 done after the HU went in - took them 5 mins.
what series sv6 do you have mate?
MY9.5 (Series 1). The SIC can be 'standard' or 'sports' mode - it's all in the programming, no need for new hardware. But you only get the two gauge version in this case.
Here's my gauges (2 gauge version):
And here's the three gauge version:
cheers man just realised i would ave to change my headunit aswell because i dont have the screen fml ;(
Yep, HU change is sorta necessary although you could leave the old one there but you'd have no radio display... You can get ex Pontiac G8 units of fleabay and have them recoded for use in your car (mine pictured above is from a G8). Totally worth it as the original SV6 HU is not as good soundwise as the level 3 unit. I compared the stock SV6/Omega (level 1) headunit with the level 2 unit in my Berlina with the new level 3 unit now in my ute and the level 3 is much improved - higher power output and clearer sound (Berlina one sorta looks like a level 3 but don't sound anywhere near as good). I think it probably helps sell the up models if the stereo sounds better...![]()
