Results 1 to 20 of 20
Like Tree2Likes
  • 1 Post By RiCeY
  • 1 Post By wizeabe
Thread: Changing VE/VZ spark plugs?
    3.8 vx executive s2
    Sep 2011
    adelaide
    Default Changing VE/VZ spark plugs?
    i was wondering if anyone has a video on changin VE/VZ alloytec spark plug cheers
    VE Berlina
    Jan 2010
    I'd be interested in the video as well if anyone has one or is willing to make one.
    Cheers.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Not really that hard.
    1. Remove the intake piping from the throttle body
    2. Theres 8 bolts on top of the intake manifold. Remove all but the front right bolt and the rearmost left bolt. This will allow you to lift the manifold to remove coilpacks and spark plugs. You dont need to remove it completely, just lift it up. Leaving those 2 bolts in prevents the 2 piece manifold from seperating and possibly damaging the gasket.
    3. Remove coilpacks then plugs.
    Note. The rearmost right side bolt is a bastard. It sits low like the front left bolt but is harder to get to being under the plenum. Youll need various length 3/8th extensions to get at it and on the VE it helps the lever up the plenum and jam a block or something in there to allow you to angle the extension into the area that the bolt is in.
    Silver Certified.
    3.8 vx executive s2
    Sep 2011
    adelaide
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    myberlina's Avatar
    myberlina is offline BAD COP! NO DOUGHNUT!!!
    2006 VE Calais
    Aug 2005
    Melbourne, VICTORIA
    Quote Originally Posted by RiCeY View Post
    ... Note. The rearmost right side bolt is a bastard...
    NOT WRONG THERE! Took me 45mins on the phone to various mates of mine to figure that one out.
    ve sv6
    Aug 2010
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by glenn l View Post
    ricey, is it worth putting on some anti seize on the spark plugs?
    It's personal preference. I never have. I've found if you leave them in there for an extended period of time that sometimes the copper paste dries out, and becomes a somewhat binding agent.
    But, that was a couple of isolated incidents. Up to you.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    I never do and havent had any issues but that being said normally it wouldnt hurt.
    Silver Certified.
    VE Omega
    Apr 2008
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Ignore the manifold replacement one, at least most of it, as you dont need to actually remove the manifold.
    Just loosen it to allow it to be lifted enough to remove coilpacks and plugs.
    Silver Certified.
    VTSS350 is offline Blown VT LS1 450rwhp
    VTLS1
    Oct 2005
    I replaced the spark plugs in my VZ commodore yesterday and it was very easy. It took about 40minutes to do in total.
    As has already been said you need to remove all the manifold bolts and lift it slightly to allow you to remove the coilpacks and plugs.
    Commodore
    Jun 2004
    NSW
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
  15. #15
    Commodore
    Jun 2004
    NSW
  16. #16
    VY SS
    May 2011
    Auckland
    Depends what's in there.
    From memory coppers are 20k, platinums are 80k and not sure about iridiums. Somewhere In between?
  17. #17
    calais06's Avatar
    calais06 is offline Donating Member
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    My alloytec has it in the manual for the 120,000km service, so just check ur manual.
  18. #18
    2006 VE Omega / Look-a-like SSV
    May 2011
    My aloytec also 120,000 just about ready, did wonder about the manifold .. If I remove all bolts apart from the 2 listed above and lifted it up is there still chance I could ruin the gasket by doing this?
    (also what a stupid place to put them - doesn't make it easy)!
  19. #19
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Don't use anti sieze if the plugs are shiny metal as you can easily over tighten the plug snapping the end off.
    Check. http://www.ngksparkplugs.com/pdf/TB-...1antisieze.pdf
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
  20. #20
    ve sv6
    Aug 2010
    thanks sabbath, ricey and surfwagon, 3 out of 3 is good enough for me.
LinkBacks (?)
  1. 01-05-2012, 12:23 PM
  2. 01-05-2012, 03:10 AM
  3. 06-04-2012, 06:37 PM
  4. 28-03-2012, 05:52 PM
  5. 22-03-2012, 02:49 PM
  6. 16-03-2012, 08:13 PM
  7. 06-03-2012, 12:37 AM
  8. 13-02-2012, 10:11 PM
  9. 13-02-2012, 03:19 PM
  10. 31-01-2012, 02:28 PM
  11. 31-01-2012, 10:18 AM
  12. 30-01-2012, 10:01 PM
  1. changing of spark plugs
    By steak000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2008, 05:26 PM
  2. Changing spark plugs
    By Egnitevt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-11-2007, 06:04 PM
  3. changing spark plugs
    By carlyboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-07-2006, 04:38 PM
  4. changing spark plugs??
    By hold-on in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2006, 02:57 PM
  5. Changing spark plugs EFI 202
    By killuminati in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-09-2005, 03:21 PM
