Results 1 to 15 of 15
Thread: radio on/off by ignition
    VE SV6
    Jun 2009
    Default radio on/off by ignition
    09 sv6 sedan
    OK I was mucking around with the on board computer system the other day - why you may ask??(rear passenger side door doesnt unlock on one press of the key) but thats another story and not my problem now.
    Ive mucked up my radio, i had it perfectly set to come on with ignition and go off with ignition off/driver door open....now I have to manually turn it on and off and Ive already left it on once after parking the car - not in the habit of turning it off manually.
    How can I get it back to how I had it originally?
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    I think theres a setting for how long accessory power stays on after the key is removed. Could be wrong.
    Silver Certified.
    VE SV6
    Jun 2009
    Yeah the way it was before - I could shut the ignition off completely, it wasnt until the drivers door was opened that the radio went off
    gottavecalaisv's Avatar
    gottavecalaisv is online now Calais' are great mate!
    Ve Calais V V6
    Jan 2007
    go into customize settings when you first turn ignition on and change it there
    VE SV6
    Jun 2009
    Its doing my head in.
    I think Ive got it set right, radio off when door opens, then the next trip it stays on....now Ive ####ed it so the dash lights are staying on, mucked around in the computer and managed to have them go off when I turned ignition off....wondering whats in store when I get to work tomorrow
    VE Omega
    Nov 2010
    I'm very interested in this, exactly what setting are you playing with? and where can it be found?
    Check out my VE Commodore My Omega Mods
    VE SV6
    Jun 2009
    Quote Originally Posted by BigBoss View Post
    Cant recall now....was something in ''customize options'' or whatever is called....anyway I tried 'reset to default' and that just stuffed me right up for a while.
    Typically though the bitch has fixed itself.....after a good flogging.
    Alls good
    09 VE SSV Sportswagon
    Jun 2011
    I have the same problem now...since I put in aftermarket gauges, about 2 weeks after the radio would stay on sporadically when opening door, then i'd close door, re-open and it would go off...now it just stays on. I have no idea what wiring we could of stuffed with to cause this
    The X Man's Avatar
    The X Man is offline Donating Member
    VE SERIES II SV6 SIDI
    Feb 2010
    Huh? I have had a look in mine and cannot find anywhere where you can change the radio settings along with the ignitioon and door. Having an amp on the fronts when i turn off my ignition the fronts go off but the rears dont. I'd rather the whole head unit shut down with the key, not the door.
    VE SV6
    Jun 2009
    Quote Originally Posted by The X Man View Post
    Huh? I have had a look in minbe and cannot anywhere where you can change the radio settings along with the ignitioon and door. Having an amp on the fronts when i turn off my ignition the fronts go off but the rears dont. I'd rather the whole head unit shut down with the key, not the door.
    No you cant....I now know this....you can change radio settings with the 'help' button on the sound system....but didnt know that initially and how all my problems in life began
    VE SV6 MY9.5
    Feb 2012
    i just bought my SV6 this week, and have the same problem.
    - Turn off ignition, radio still plays.... open door and it turns off
    - Turn off ignition, radio still plays.... open door but doesnt turn off...
    - open door, close door, open door again and it turns off
    - open door, close door x10 but still doesnt turn off
    the above are the different scenario's im getting... there doesnt seem to be a pattern.
    might play around in the 'customize settings' menu tonight, will post back findings.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    VE Omega
    Nov 2010
    Probably an intermittently malfunctioning door switch.
    That is what i was thinking.
    VE SV6 MY9.5
    Feb 2012
    Quote Originally Posted by RiCeY View Post
    Yup, just did some more testing, and noticed the "Car Door Open" dash light doesnt come on when i open the door.... hence the car thinks my door is still shut and keeps playing the radio.
    It stays stuck 4/5 times i open the door.
    I couldnt really see where the door switch was, anyone know ? got pics ?
  15. #15
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Door switch is part of the latch/actuator assembly and not serviceable seperately.
    Silver Certified.
LinkBacks (?)
  1. 29-04-2012, 10:34 AM
  1. On glass UHF radio antenna. (Radio installers)
    By Stretchomatic in forum Electrical Wiring / Questions
    Last Post: 01-09-2011, 01:41 AM
  2. VS Exec radio to Calais radio
    By Super Coach in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2010, 07:43 PM
  3. No Ignition Spark from ignition coil?????
    By Huddo001 in forum V8 Development and Modification
    Last Post: 14-04-2010, 06:54 AM
  4. Radio stays on after key removed from ignition
    By moppy_j in forum Car Audio
    Last Post: 03-11-2009, 02:09 PM
  5. Ignition problem help needed, Ignition lead fallen out??
    By boourns in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2008, 05:04 PM
