Hey Lads,
I need to find a 12v accessory wire in my Omega that will stay on (even when the car has been turned off) until I open my door like how the stereo works. Does anyone know where such a wire can be found?
Check out my VE Commodore My Omega Mods
What you powering up? Depending on how many amps it pulls you could splice into the factory 12v port.
Silver Certified.
Thanks RiCeY, I plan to use it to power my LCD HVAC controller so bugger all amps. What is this 12v port you speak of?
In the centre console compartment.
Silver Certified.
It should stay powered up till you open the door along with the stereo etc? Plug something into it and test my theory I could be wrong haha
Silver Certified.
Ok just tested it, the sig lighters die as soon as the key is removed, unlike the stereo which will stay active until the door is opened.
Damn.
Maybe try and splice into the radios power source?
Silver Certified.
I have also probed the 12v wires going to the stock HU and all three that i could find are always on. So I'm assuming the stereo is getting its on off commands from some GM LAN magic.
Ahh k thats possible.
Ill have a read and get back to you.
Silver Certified.
Should be same...
Youre right theres 3 wires with constant battery voltage all orange with a dark blue trace.
The on/off command must come via the CANBUS.
Ill keep thinking.......
Silver Certified.
hey mate, if your still looking for the remote\accessory wire
VE accessories wire
connecting amp to ve original radio
those 2 posts will be of massive help, good luck
Hey big boss how did you go with ye install I have bought the same LCD controller and need to wire it up
Cheers Timmo,
Hey U Mirin to get it to work properly i have ordered a solid state timed relay that should do the job. Currently it works but every time i restart the controls default back to some useless setting so i need to mash a couple of buttons to make it work properly. the LCD can be wired up to the GM LAN wire located at the head unit plug or behind the glove box.
If you done want a relay solution you could hook it up to the power windows relay witch should also work assuming they run at 12v.
or you could get from holden an emergency vehicle wiring harness which is indepenent of the the main harness and any accesseries you add will not mess with computers or settings, may be able to find one at wreckers.
what we have here,is a failure too communicate!!
Ohkay cool thanks alot what colour is the GM LAN. Wire ?
Champion thanks alot
Got it all wired up but the hvac is off and I carnt turn it on what GNLAN wire did you use ? Where was it located
