Hey All,
Just wondering if it is possible to make the accessory 12v power jack (sig lighters) stay on like the radio when the car has been turned off but the door has not been opened? I'm asking because this is what G8s do and i would really like this function in my series 1 Omega, I'm hoping it is just a setting somewhere...
Check out my VE Commodore My Omega Mods
pull the power from the radio.....
Thanks but the power leading to the stereo is constant, it uses it's GMLAN connection to turn off and on.
Bridge the accessory relay so its always live?
Silver Certified.
Ive had a look at the schematics. The 12v accessory plugs are controlled by Relay R8 Accessory Power Relay. This relay is activated by the BCM.
There is another relay R1 Retained Accessory Power Relay which I presume means it stays live after IGN is off. It controls power windows. It's also controlled by the BCM. Im wondering if you could patch the accessory plug to be controlled by that relay giving you power without IGN. It may only be for a limited time though...
Silver Certified.
That sounds perfect!!!! RiCey you are a genius! limited time is fine the HVAC unit that it will be powering only really needs a split second after power off. Is this R1 located in the main fuse box? or somewhere else?
Should be in the main box.
Silver Certified.
To save some data, BTW it is now all better due to a software update and or a timed relay.
