Results 1 to 5 of 5
Thread: VE II SS Thunder Ute - Speedo way out & GPS alert distance seems really short
    VE II SS Thunder
    Jan 2012
    Sydney - North
    Default VE II SS Thunder Ute - Speedo way out & GPS alert distance seems really short
    Hi all - just new on here - just picked up an 8 month old Thunder today. I noticed on the way home the speedo seemed to be reading high, so grabbed the Garmin GPS out of my other car to check. Found that when the speedo is showing 100 the GPS was showing just over 80 so it is way over the usual 3-5%. Has any one else found their speedo out this far.
    Also noticed that the alert for speed cameras and red lights etc seems really short - maybe 100-150m from the actual Camera etc. Happened 7 or 8 times so it is not a one off. Is there any way to adjust the alert disatance to give you more warning?
    Thanks in advance for your help!!
    Cheers.
    VE II SS Thunder
    Jan 2012
    Sydney - North
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    VE II SS Thunder
    Jan 2012
    Sydney - North
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    May have the wrong calibration is the ECU in regards to wheel/tyre size but even that wouldnt cause the speedo to be out so much.
    Be worth taking it to the dealer as its under warranty and wont cost you anything.
    Silver Certified.
  1. Speed alert set to permanent digital speedo.
    By Brett_jjj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2010, 02:32 AM
  2. Holden Commodore Speed Alert/speedo
    By MATT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2009, 03:04 PM
  3. Speed Alert into electronic speedo?
    By Ross D. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-02-2009, 09:25 AM
  4. Possible To Get Speedo On Speed Alert In Vs
    By Gobbles in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2007, 06:48 PM
  5. speed alert into Digital speedo
    By sassy_41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-05-2006, 07:44 PM
