Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By RiCeY
Thread: Dual zone A/C issue
    Luke V8's Avatar
    Luke V8 is offline AKA Luke!
    VE Commodore SSV
    Feb 2011
    Default Dual zone A/C issue
    Hi All,
    The passenger side on the aircon is only blowing warm/hot air. It doesn't matter if through dash vents, foot vents etc is just comes out warm in the passenger side only.
    And yes, I have checked that it is set to cold :-p
    Would this happen if it needed a recharge?
    VE Calais V 6.0L
    Aug 2011
    I am thinking that the problem is the dual zone blend door motor module.
    This module is used to direct air to the cabin heater core, to heat or cool the air a required.
    (It directs more air to the heater from warmer settings, and less air for cooler settings).
    It is possible that the motor is stuck, or the module may have issues....
    hope this helps
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Not a module, its an actuator. Though the HVAC module which controls everything could be the issue.
    Try a vent door actuator relearn. With IGN on, press and hold the rear demist button till you hear the vent actuators start moving. They are fairly quiet so have all doors and windows closed and fan/radio off so you can hear it.
    Once they stop try the AC and see if its fixed.
    Do you hear any clicking in behind the dash when you IGN on or change modes?
    Silver Certified.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    VE S2 SV6/A6
    Apr 2011
    It's driver/passenger.
    I'm not sure what zone the back vents are linked to. Never tested that one
    Current Ride: 2011 VE Sedan - In Voodoo of course.
    Last Ride: 2004 Subaru Liberty GT, Twin scroll turbo, tuned, Bilsteins, sway bars, no rice, 420Nm
    Also Own: 1964 EH Wagon, modified interior, minor modifications outside
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    MY9.5 VE SV6 Ute
    Dec 2010
    Northern Victoria
    Does the screen on the stereo show DZ or SZ? If it's SZ, whatever the driver's side temperature is set to will come out the passenger side. Just a thought only because I did that once...
    Luke V8's Avatar
    VE Commodore SSV
    Feb 2011
    Thanks all. Tried relearning and it didn't work.
    Even If I put it to single zone and cold the passenger side (face and feet) and rear vents come out warm but drivers side nice and cold...
    Arrggggghhhhh
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Failing that take it somewhere to check for codes relating to the HVAC system.
    Silver Certified.
    Luke V8's Avatar
    VE Commodore SSV
    Feb 2011
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Move the gearstick back away from the facia. Wrap you fingers up under the base of the facia and pull. It can take some force but it will come off, just be carefull not to hit the gearstick with it.
    Silver Certified.
    Luke V8's Avatar
    VE Commodore SSV
    Feb 2011
    Johnsy's Avatar
    Johnsy is offline ★★★★★
    HSV R8 LS3
    Oct 2005
    C/Town
    Back is set to face as stated above... and the dual zone does work in the back as well even though the vents are close and doesn't make much difference unless its cranking and you have them pointing away from each other...
  15. #15
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by Luke V8 View Post
    It's auto
    Still has a gearstick
    Silver Certified.
  16. #16
    Luke V8's Avatar
    VE Commodore SSV
    Feb 2011
    Just down at Holden at the minute - one of the doors for the aircon is jammed or something. .. About to find out the damage
  17. #17
    Luke V8's Avatar
    VE Commodore SSV
    Feb 2011
    turns out its a clip that aids on opening & closing the aircon doors (behind the dash). A fairly common problem they tell me. Have to take the dash out to fix.
    He also informed me that i actually have about 4 months left of warranty! so not going to cost anything
  18. #18
    Johnsy's Avatar
    HSV R8 LS3
    Oct 2005
    C/Town
  19. #19
    Luke V8's Avatar
    VE Commodore SSV
    Feb 2011
    Cheers mate / will let you know after Tuesday if sorted!
  1. Getting dual zone AC into my SS (can it be done and what parts will I need)
    By Morpheus in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-09-2010, 08:52 PM
  2. Dual Zone air conditioning
    By Calaber in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-05-2009, 01:23 PM
  3. HELP - WH statesman dual zone climate control, interior fan no work
    By Caprice5L in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-12-2008, 06:15 PM
  4. VZ Dual Zone Climate control symbols
    By hingo1983 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-10-2008, 08:05 AM
  5. VX Calais Dual Fuel Issue
    By jake_au in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2006, 01:32 AM
