how hard is it? is it just as easy as clip on clip off ? cant seem to find any tutorials around
cheers
Internal or external?
external .. sorry i forgot to mention that!
Open the door and youll see a grommet just inside the door end above the latch. Pull out the grommet and theres a 10mm bolt in there. Remove that and the lock section will come out, carefull as the actuating rod will be hooked into it, just unhook it.
Now from memory the handle slides towards where the lock was and comes out.
Silver Certified.
sounds simple so i dont have to remove interior trim:S?
Originally Posted by Reaper:
Originally Posted by Jecs:
Not unless you drop the bolt...
