Hey all
Just wondering how I can make my air con colder as it isn't as cold how it is, will a re gas do it or is there anything else that needs to be done
Thank you
I agree, the VE aircon is crappy, I wonder if there is a simple way to make it colder. Changing out the compressor maybe?
Having the air on recirculate can help, once the interior has cooled down a bit I've found its a bit cooler than using fresh air.
Oh, and +1 for the ice box comment.. mine is fantastic, it may not be the fastest system to cool down but any drive longer than 15 mins with a/c on flat and its icy cold
You can try and get the temps colder when you re-gas. But you risk icing up the system potentially.
Originally Posted by Reaper:
Originally Posted by Jecs:
System will only ice up if the evaporator temp sensor malfunctions.
Silver Certified.
Mine is nice and cold, so it's not a problem with the VE like iUte said.
I'd take it to an auto elec that does air con and see what they can tell you. There's nothing we can tell you to do that will make it colder.
Mines plenty cold enough too, even on fresh, that I prefer to run it on.
Same here,mines icy cold...
I think i just expect too much from my Air Con, both the VE's I've had AC's have worked about the same.
They don't work anything like the Toyota Landcruiser AC units is all I mean, those things just about leave frost on the air vents.
They don't seem to be as fast as Subaru units either, but still get the car more than cold enough for me in just a few minutes on a moderate setting. Have you got your fan on High and temp on C or run it on Auto ?
If you want Cruiser icicles in your Holden go buy a Landcruiser compressor then get an adaptor kit made up and fitted. probably 2 grand later you'll be in VE icicle heaven.
The evaporator sensor controls the temp of the evaporator and the air passing through it before it exits the vents, this minimum temperature wont change by changing the compressor.
Silver Certified.
A simple thing to try, hose out the condensor (front of radiator) bugs,grass etc build up in there which will make the system have high head pressure, which in turn will shut the compressor off early. We run earthmoving gear at work, and alot of the time a poor a/c performance is caused by blocked condensor. Worth a try anyway. B.T.W my air con is cold in the ssv, and bloody freezing in the prado!.
Cheers.
[CENTER][URL="http://forums.justcommodores.com.au/showthread.php?p=490264#post490264"]
Mine wasnt getting very cool, got it checked has a tiny leak somewhere they re oiled and re gassed it with dye, gets freezing real quick now, cant have it on 17 degress anymore as my hands go numblol
The AC in my ute use to be fantastic, as someone has already said, wasn't the fastest AC to cool the car down, but once it was cold, it was freezing!
Sadly now something is playing up and the AC won't go cold, I'm leaning towards it needed a re-gas, so hopefully that'll fix it.
my 07 omega works heaps better than my old toyota hiace ac , but it was the old 2-80 type but ,ya know 80ks 2 windows down type , but yeh the comm air con gets like a ice box .
the bigger the wave the longer the hang time , free ride jet skiing
Fill the system with LPG, that'll get it nice and cold, plus you get some awesome explosions when you crash and large fines if you get caught.
