Results 1 to 7 of 7
Like Tree4Likes
  • 3 Post By RiCeY
  • 1 Post By RiCeY
Thread: Satnav
    VE BERLINA
    Feb 2010
    Default Satnav
    HI ALL WOULD LIKE TO KNOW IF ANYONE HAS HAD A VDO DAYTON MODEL No MS5200HD FITTED TO A VE COMMODORE BERLINA THAT DOES NOT HAVE A NAV BUTTON ON THE RADIO FACIA AND ALSO IS THE SPEED SENSE MAGNETS REQUIRED BECAUSE I THOUGH THE SPEED SENSE WAS THROUGH THE BCM OR OTHER ANY HELP WOULD BE GREATLY APPRECIATED, I HAVE THE KIT ALREADY TO INSTALL, OR IS IT NOT COMPATIBLE WITH THE BERLINA, MAYBE ONLY CALAIS OR ABOVE MODELS, I HAVE A GARMIN INSTALLED INTO TOP OF DASH I DID MYSELF BUT BOUGHT THE DAYTON SO I COULD REPLACE THE GARMIN WITH A REVERSE CAMARA
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    i think he is pi**ed off
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    Ghost's Avatar
    Ghost is offline Donating Member
    Vr Commodore Executive 1993
    Sep 2011
    Adelong New South Wales
    VE BERLINA
    Feb 2010
    sorry about the cap lock anyway at least you can read it, i dont think people on this forum should judge people just because of a minor over site thanks anyway guys, anyone with some useful info on this Sat Nav model
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    VE SV6 MY08
    Sep 2011
    Hey donthree,
    Sorry but I have no idea at all about that particular unit. I did put an aftermarket h/u in my SV6 that has sat nav though. After much searching and some trial I couldn't find a nice easy place to tap into the vehicle speed sensor. I think I found the sensor & colour wire inside the gearbox, but.... Anyway the only advice the one guy at Holden could give me was a wire that runs along the rear axle from the wheel sensor. I couldn't be arsed running a wire from there, so I've left it unconnected. It really isn't an issue as your nav should still work. It might not be quite as accurate if you don't have enough satellites (never bothered me) and won't track you through tunnels. Living in Brisbane (& hating Cambell's tunnels with tolls) I have no issues not having enough satellites. The only time I'd see it really being useful is if there's a turn-off in a tunnel you need, or a turn-off almost immediately after and before re-establishing a connection.
    I'm guessing the speed pulse you want is converted to digital info into the canbus, unlike older models that took the pulse all the way to the speedo. Not sure where this is done, I hoped there was a pulse from the gearbox to the control module in the driver's side kick panel, but I couldn't find it. Please let me know if you find one other than the wire on top of the axle.
  1. satnav
    By vussman in forum Car Audio
    Last Post: 23-01-2012, 10:32 PM
  2. satnav/dvd
    By vussman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-01-2012, 09:16 PM
  3. FS : genuine HBD VT/VX/WH Satnav LCD surround // SA
    By Drew in forum Parts And Other Items For Sale
    Last Post: 16-08-2008, 06:20 PM
  4. VE SatNav system availability
    By Rogues in forum VE Holden Commodore (2006 - ?)
    Last Post: 28-09-2007, 11:07 PM
  5. any such thing as a cd Satnav combo???
    By japozzi in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-09-2006, 09:14 AM
