Results 1 to 7 of 7
Thread: VE front suspension
    VE BERLINA
    Feb 2010
    Post VE front suspension
    hi has any one had a knocking noise from front left strut tower car only done 82 th klms i have been told is strut bearing and is a common fault and would you know if it was a recall under warranty thanks guys /girls any info appreciated
    07 VE CALAIS V - V6
    Mar 2011
    Illawarra NSW
    yes it could be that as its a common problem and I had the same issue with knock and replaced the mounts and bearing with similar to these (NOLATHANE STRUT MOUNTS FOR VU V2 WH MONARO VE WM HSV | eBay) and issue resolved.
    no warranty for me as its was deemed "fair wear and tear".
    VE BERLINA
    Feb 2010
    Thank you for that womble66, 95% has been highway travel still not good for the billion $ baby.
    07 VE CALAIS V - V6
    Mar 2011
    Illawarra NSW
    same here all hway kms and done at 150K km. i would just say low quality rubber mounts used by gmh.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Nice how they write escape clauses like Wear and Tear into the warranty lol. So they give you a 100000 k warranty, then pick and choose what they will actually cover ? Interesting.
    The trouble seems to be due to these rubber mounts being fluid filled, so there is less rubber in these things to take the force of the bumps and they crap themselves in no time. Its all about making the car feel as comfortable as possible so they sell more cars, even if they fall apart sooner because of it.
    Find some heavy duty solid rubber ones and they will last double the time, but with a slightly bumpier ride. The warranty is obviously worth nothing anyway so it don't matter if you use holden spares or not from here on.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Pretty sure they arent fluid filled, never seen one leak.
    We always replace under warranty, no wear and tear BS. Try another dealer if you get that treatment.
    Silver Certified.
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    ^^^ This. Had mine done twice under warranty before giving up on OE rubber.
  1. Front suspension
    By votality in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-09-2011, 07:00 PM
  2. vp front end suspension
    By VRAddiction in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-09-2010, 06:38 AM
  3. Front Suspension
    By TrustNo1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2010, 10:01 PM
  4. front suspension help!!!
    By Muzz-VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2008, 11:06 PM
  5. Front suspension
    By full_noise in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-01-2007, 10:09 PM
