Results 1 to 8 of 8
Thread: Engine light
    1998 senator signature
    Nov 2009
    Default Engine light
    Installed a ramjet ort on monday & tuesday night the engine warning light has come on. Im assuming it has got to do with the airlow playing around with the sensors. Getting it tuned & exhaust in the next 2 weeks. Just wonder ok ng if its fine 2 keep driving it with the light on? Its running fine so hopefully stays like that.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Make sure theres no air leaks between the MAF and the throttle body as this will throw an engine light due to unmetered air entering the engine.
    Also ensure the MAF is plugged in correctly.
    Silver Certified.
    VE SS
    Jan 2012
    New South Wales
    Don't risk it mate I bet you any money your fault code will be "lean fuel mix bank 1&2. Get the tune first.
    VE (knock, knock, knock) SS Series 2 2.5" Stainless Exhaust, Pacemaker Tri Y Headers, VCM OTR, Custom Tune...
    "Torque Is What Breaks Shit"
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    yep more airflow entering the engine - I'm surprised no one mentioned this in your other thread
    EASY $30 DIY Cold Air Induction!
    Quote Originally Posted by stuffedifiknow View Post
    would this mod work like forced induction.
    Nov 2009
    Do you think cleaning the maf sensor will take the light off? Or it will need a tune
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Needs a scan tool to read what the actual fault is then go from there.
    Silver Certified.
    VE SS
    Jan 2012
    New South Wales
    Need a tune mate OTR's screw the computer up as in it gets confused. Just a fuel mixture tweak will sort it.
    VE SS
    Jan 2012
    New South Wales
    But almost any money bank 1&2 lean fuel mix that's what most guys get.
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. Vt 5.0 idle problems and missing also engine light and oil light come on
    By vtss5.0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2011, 07:32 PM
  3. HELP Engine Light / Transmission light and rough gear changes
    By flash20005 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2010, 03:34 PM
  4. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  5. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
