Results 1 to 23 of 23
Like Tree5Likes
  • 1 Post By Ed
  • 2 Post By Hangman
  • 1 Post By goldcoastr
Thread: Car Door Just wont open LOL
    Ve wagon
    Jan 2012
    goldcoast, QLD
    Default Car Door Just wont open LOL
    Ok so i get in my Ve wagon today drive to the post office then when i went to get back in the door handle from the out side wont work
    i managed to open it once from the inside then after i shut it to drive home its again not opening, ether the inside handle or the outside handle will open it, the cable on the door handle i can hear its attached but i reckon its come out of the inside door panel.
    basicly the problem is not whats wrong as i can find that out once i get the door open, the problem is How to OPEN THE DOOR WITH OUT THE HANDLE LOL
    help!!!!!!!!!!!!!!!!!!!!!!!!!!!! lol
    Zarconia's Avatar
    Zarconia is offline Outrageous Fondler
    96 VS Executive Series 2
    Aug 2010
    Rockhampton
    Ve wagon
    Jan 2012
    goldcoast, QLD
    VE SV6 II Ute
    Aug 2009
    Melbourne, Victoria
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Quote Originally Posted by Ed View Post
    leave the window down
    Dukes of Hazzard style
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    VE
    Mar 2011
    n
    How about you fix it, then you won't have to climb thru the window.
    I would start by disconnecting the battery, and removing the door trim.
    Call me a party pooper....
    HIDs.....LEDs..... DRLs..... CHEV Badges..... ->
    Hangman's Avatar
    Jan 2010
    His problem is he can't open the door, hence can't remove the trim.
    Ghost's Avatar
    Ghost is offline Donating Member
    Vr Commodore Executive 1993
    Sep 2011
    Adelong New South Wales
    ve ss
    Feb 2010
    Gold Coast
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Rufys is offline Banned
    VE Series II Calais Sportwagon
    Aug 2011
    Use an angle grinder to get to the mechanism, open door, repair mechanism, drive to panel/paint shop, repair door. DONE!
    VE Omega
    Nov 2010
    how about trying to remove the rubber surround on the back edge then try playing with the locking mechanism, If that is even possible....
    Check out my VE Commodore My Omega Mods
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    wondering if you removed the two screws that are accessible with the door closed (inside lever, under the arm rest from memory), could you still unclip the trim from the top, at least partially, and maybe get an arm in? But then there's the plastic sheeting...
    just thinking out loud. Not sure if the top clips are dependent on the rest of the screws being removed first.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    You can pull the top outwards unclipping it from the trim that runs along the base of the window.
    How far Im not sure, never had to do it.
    Silver Certified.
  15. #15
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    Quote Originally Posted by RiCeY View Post
    That's what I was thinking - with the middle screws gone, there might be enough of a cavity to reach in - probably need to rip through the plastic - and it would be a lucky dip as to whether you could reconnect anything that way, particularly as it would get tighter towards the edges and you'd be able to see exactly FA - maybe worth a shot though before reaching for the grinder?
    If you're Mrs has skinny arms.... maybe?
  16. #16
    Ve wagon
    Jan 2012
    goldcoast, QLD
    ^^^ yeah at work tonight was thinking this then just got home to read u suggest it, cause I'll I need to do is pull the cable up then I can open the door, going try one wish us luck lol
  17. #17
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Theres two cables, one for the lock and one for the handle that run along the door from the inside handle.
    If theyve become disconnected from the inside handle you should be able to pull that end up then pull the cable to open the door.
    Silver Certified.
  18. #18
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
  19. #19
    Ve wagon
    Jan 2012
    goldcoast, QLD
    Yeah going need cut the Hsv leather door panel
    Or break where the handle IS and try to fix it after as I have a spare
    To some other comments it's a 2010 model under warranty but not this door as It was replaced with a second hand door also the door panel I got recently for a upgrade
    To angle grinder r NO lol
  20. #20
    Ve wagon
    Jan 2012
    goldcoast, QLD
    Yeah going try again in morning but it is almost impossible to make even the slightest gap, also the cable is still attached to the handle it's just dis lodged out of the panel where it clips in, so basically when u pull the handle it doesn't move the cable enough
    Maybe going just break the handle tomorrow and pull the cable through then I can just replace the handle cause I have a spare
  21. #21
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    It clips in at the handle so you may be able to reach down and clip it back in, or just reef on it to open the door.
    Silver Certified.
  22. #22
    Ve wagon
    Jan 2012
    goldcoast, QLD
    yup fixed thanks every body for your help
    suprised it doesnt happen more offen as they just can rattle loose the cables, i did change the speakers in the front 3 days ago so its maybe i didnt put it back in tight enough how ever i have taken the door panels off bout 3 times already on each door on this car & this was the first time i had issues with the lock cables, still got to take the panel off in a few days to do some work so might sort silcone them in so make sure it never falls out again until u want it to
    thanks (admin/mods can lock or delete) cheers
  23. #23
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    Good to hear it worked out.
  1. Fuel door wont open?
    By Maxxiz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-11-2011, 07:41 PM
  2. My door wont open
    By eXphoid in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-12-2010, 11:14 PM
  3. Door wont open :( Need advice
    By Toddlez in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-09-2010, 10:28 PM
  4. Door locked wont open???
    By reddog in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-07-2008, 07:49 PM
  5. Passenger Door Wont open
    By Heffer_Slayer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-04-2007, 01:48 PM
