Just thought I would let you all know that the second recall/rework has been sent out for VE. Only 58 vehicles are affected, and these could have possibly had incorrect check links fitted to LHF door, which if door is closed while window down, the glass would break. Nothing to major.
Thanks for the info, I'll forward that to my uncle..
1st recall. 2nd rework.
Could you post the chassis numbers/build dates for this recall and the previous one?
There was no previous recall. As Drewins said, this is the FIRST recall but SECOND rework... The other 'rework' was before any VE's were sold and they were fixed or checked at the factory and at Dealers.Originally Posted by sfordham
just great recall the VE already, I personally find the shape of the car 2 be a bit weird having seen the omegas almost every day,but I'll wait till I see a ss up close then make a major judgement
Cheers.![]()
* RVN 355 *
i was told of a more serious problem today at my local dealer...
Apparently they are having electrical issues with the VEs and there is a problem with voltage drops happening.
What happens is the computer voltage fluctuates and it thinks there is a fault in the system. Apparently two faults and the car will flat out refuse to start. Yep, imagine coming back to your car and the bastard wont start even though there is nothing really wrong with it.
Not sure if they have a fix for it yet.
