Page 3 of 3 FirstFirst 123
Results 51 to 57 of 57
Like Tree7Likes
Thread: VE SV6 Tyre Wear
  1. #51
    Holdfast is offline Donating Member
    VE & VL
    Jan 2005
    Default Bridgestone Potenza SO3 245/45ZR18 Purchase Question - Age / Problems
    Anyone remember these?
    Potenza SO3's are discontinued and were replaced by the Adrenalin Potenza RE001and the RE001 have been replaced by Adrenalin Potenza RE002.
    s03
    My question is, are these old tyres (Bridgestone Potenza SO3 245/45ZR18 ) ok to purchase? They are new.
    Would the rubber in them be too old?
    Would they wear ok?
    H
  2. #52
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
  3. #53
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    I estimate the camber is currently about +0.2 degrees so i'm curious if i rotate the eccentric bush thingy to say -0.2 - 0.5 if that would cure the tyre wear ... or at least even it up by wearing more on the inseide which has more tread left.
    How much adjustment is there in the bush o the inner control arm ?
  4. #54
    greenacc's Avatar
    VE Berlina
    Jul 2008
    Quote Originally Posted by RiCeY View Post
    Most people say tyres have a life of around 5 years.
    Agree with 5 years although if you were gauranteed they were stored indoors in a cool place out of sunlight you could reasonably extend that 5 years by a couple more.
  5. #55
    VE & VL
    Jan 2005
    Quote Originally Posted by greenacc View Post
    Ok, cheers.
    They might be a bit too old then.
    H
  6. #56
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    If you have FE1 the rear camber should be –0.5° + 0.35°/–0.55° and the toe should be +0.17° ± 0.1° per wheel with a total of +0.33° ± 0.2°
    Silver Certified.
  7. #57
    greenacc's Avatar
    VE Berlina
    Jul 2008
    >jacks up Vehicle and digs around in socket set.
  1. tyre wear
    By sue in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-03-2006, 05:55 PM
  2. tyre wear
    By HOTPLATE in forum General Discussion
    Last Post: 11-10-2005, 01:18 AM
  3. Tyre Wear on VY
    By Tapper in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-07-2005, 10:02 PM
  4. VP IRS tyre wear
    By MasterOfReality in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2005, 02:13 PM
  5. VY Tyre wear
    By keithVYSS in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-09-2004, 06:33 PM
