Results 1 to 6 of 6
Thread: 12 Volt Auxiliary Power for Caravan
    VE Lumina 2007
    Jan 2006
    Question 12 Volt Auxiliary Power for Caravan
    On previous models Vt, VX, VY, I have taken 12volts for my caravan fridge and power etc. direct from the battery positive terminal through a decent size fuse.
    I am an electrician so I dont have any problems doing the work, however with all the changes in the VE I hesitate to this but it still seems the best way to do it in regards to voltage drop etc.
    Has anyone out there done this work as yet?
    If so any dramas doing it that way?
    Thanks for any help.
    Keith.
    BOY1236 is offline Crazy dude in a V8
    VE SS (4-speed auto)
    Dec 2007
    Saudi Arabia
    Hmmmm ... Good Idea
    I never thought of that before ... the VE is perfect since the battry is on the back (SS)
    thanks mate
    Really really ... Fighting Temptations
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    i dont think you should worry to much, if its connected while the engine is running the alternator will adjust itself accordinly to keep voltage and amps consistant
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    CSP
    CSP is offline Banned
    my car
    Sep 2007
    There's a 12volt optional accesory socket for the boot. It's a $30 dealer fitted option.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by Cousin Slow Poke View Post
    if he's got a decent setup in his caravan that wont do it + accessory power for a trailer/caravan dont use cigarette liter sockets
    usually they use 12 pin trailer plugs (i think its 12) or a positive and negative sliding contact plug/socket sort of thing
    VE Lumina 2007
    Jan 2006
    Talking Job Done!
    I wired the Aux. supply straight off the battery positive terminal with a 30 amp auto reset circuit breaker, tested it on load, no problems came up.
    At the same time I wired the electric brakes in and tested OK, I also used a 30 amp breaker on these no dramas and tested OK.
    The reason for the hesitation in the first place was I could not find much on the forum about it and got some obviously bad info. around the traps that the BCM may not like it and give out weird messages etc. However all appears OK which is what I would have expected.
    Thanks for the replies.
    Keith.
  1. caravan 240 volt wiring
    By shonky12 in forum The Pub
    Last Post: 21-03-2008, 08:53 AM
  2. home made caravan
    Last Post: 19-03-2008, 06:25 PM
  3. 12 volt power outlet for wagon
    By rjt in forum Electrical Wiring / Questions
    Last Post: 09-02-2007, 09:04 PM
  4. Replies: 1
    Last Post: 24-04-2006, 06:58 PM
  5. 12 Volt power for VK Calais after market dizzy
    By Rossco in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-03-2006, 05:32 PM
