Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VE Holden Commodore (2006 - ?)
VE Holden Commodore (2006 - ?) Talk about anything relating to the VE Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 22-07-2008, 06:40 PM
Ride: VE SV6
Trade Rating: (0)
mmrdb Executive
Unhappy Ve Door Locks
Greetings,
Just a quick question in relation to the remote door locks on the VE: Do VE commodores have a deadlock mechanism? The reason I ask is that the VE owners manual doesn't mention anything about deadlocks. My old VX had deadlocks. This was activated by pressing the remote key on lock twice. The cars indicators would give a long flash (approx 3 seconds) to indicate the deadlock is activated.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 22-07-2008, 06:52 PM
trosal's Avatar
Ride: VE SV6 ute A5
Trade Rating: (0)
trosal Berlina
Quote:
Originally Posted by mmrdb View Post
Greetings,
yes & no, there have been some reports they do in earlier models but later not, what you can try is sit in the car and press it twice then open the door by the lock on the door and it should set off the alarm, well in my case anyway.
__________________
The Mad Dutchman
  #3
Old 22-07-2008, 07:22 PM
big m's Avatar
FIGJAM
Ride: vslll v6 2000 olympic series ute, vp v6 sedan
Trade Rating: (0)
big m Executive
not sure if this would help but with the vs the deadlock was key activated as you had to push the button to lock it and then stick the key in the door and then turn the key all the way to the left and pull it out once again not sure if this is the case with the ve
__________________
Homer: "for once in my life someone is calling me sir without (your making a scene)"
  #4
Old 22-07-2008, 11:15 PM
Supe's Avatar
Supe
Ride: VE Calais 6.0
Trade Rating: (0)
Supe Executive
My 2006 Calais has remote control deadlocking. I just press the key to lock it twice within about 4 seconds and it does the extra little bit.
  #5
Old 23-07-2008, 07:29 AM
NickVR's Avatar
HCC MEMBER
Ride: VR Executive A4 V6
NickVR Calais
Quote:
Correct. All VE's have this feature. It was standard from the VT onwards. VP-VS was key activated.
__________________
  #6
Old 23-07-2008, 08:44 AM
twise as fast as you !
Ride: VE SS (4-speed auto)
Trade Rating: (0)
BOY1236 Executive
It will do the "Beep" if you lock it twice, but it's not deadlock for the doors, it's for the engine
__________________
Yes, we drive 200+ all the time, So What ??
they make cars to be driven fast,don't they ?
  #7
Old 23-07-2008, 11:33 AM
Banned
Ride: 2007 E-Series HSV Clubsport R8
Cousin Slow Poke Caprice
Quote:
The reports are mixed because people aren't testing it correctly. Yes the alarm will go off if you get in, lock the car, manually unlock the door and open it. However the deadlock feature (as per VT-VZ) was to press the lock button on the remote twice. This would mean that manually unlocking the car from inside was not possible. This is not a feature on the VE. See below...
Quote:
This method doesnt work on the VE.
No it doesn't...
Quote:
Wrong!
This topic has been done to death...
NO VE HAS A DEADLOCK FEATURE FOR THE DOORS!!!
Don't believe me? Sit in your car (VE), lock it, then lock it again (how the old deadlock feature works) and then unlock the door manually and get out. Remeber though, to unlock a VE door manually, the locking mechanism "rolls" forward, not back. People who have said their doors are deadlocked are those that are trying to unlock the door by rolling the mechanism back.
It was standard on VT-VZ but was removed by Holden for the VE with the official reason being that it was some sort of safety issue whereby people could become trapped in the car.
  #8
Old 23-07-2008, 12:11 PM
NickVR's Avatar
HCC MEMBER
NickVR Calais
I stand corrected. There you have it. I will try this but I did not know this info. Thanks Cousin Slow Poke.
__________________
  #9
Old 23-07-2008, 01:20 PM
Donating Member
Ride: N/A
Holdfast has disabled reputation
My VE Commodore purchased late May 2008 (MY09)
Be aware that if you sit inside your car:
Manually lock all of the doors.
Now lock and alarm the car as usual using the touch pad on the key.
Wait until the console lights go off.
Then try to unlock the car using the unlock mechanism which is located by the handbrake.
You will find that the unlock mechanism is disabled.
You can either use the touch pad to unlock the car or;
Unlock the car manually as previously mentioned.
  #10
Old 23-07-2008, 01:57 PM
Banned
This has nothing to do with the deadlock feature being discussed.
The deadlock feature makes it so that the car cannot be unlocked from inside AT ALL. If you were locked inside a deadlocked VT-VZ you would have to smash a window to get out.
  #11
Old 23-07-2008, 06:05 PM
1991_Vn2nV's Avatar
A 4 and a 6... Wheres 8?
Ride: 1991 VN Berlina & MY96 Subaru Liberty GX
1991_Vn2nV ClubSport1991_Vn2nV ClubSport
I can definitely understand the safety issue, however its good for security.
Is there anyway it could be added as a feature aftermarket?
  #12
Old 23-07-2008, 06:43 PM
NickVR's Avatar
HCC MEMBER
NickVR Calais
Just tried this and there is no dead lock. Tried this on a VE berlina. I would prefer they had it but not much you can do I guess. It was a good feature cos it makes it harder to break in.
__________________
  #13
Old 23-07-2008, 07:17 PM
Ride: VE SV6
Trade Rating: (0)
mmrdb Executive
Smile
Thanks CSP. I do believe you. All your quotes make sense. I now know that VE's do not have a deadlock mechanism for the doors. Thanks to all others for your input with this subject.
  #14
Old 23-07-2008, 07:36 PM
