Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VE Holden Commodore (2006 - ?)
VE Holden Commodore (2006 - ?) Talk about anything relating to the VE Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 27-08-2008, 08:27 PM
1991_Vn2nV's Avatar
A 4 and a 6... Wheres 8?
Ride: 1991 VN Berlina & MY96 Subaru Liberty GX
1991_Vn2nV ClubSport1991_Vn2nV ClubSport
Question Drive By Wire Pedal
Can anyone give me a quick run down on the pedal setup with the VE's drive by wire system?
i.e. How it works? I assume a module of some sort is connected to the pedal?
And most importantly, are V6 accelerator pedals interchangeable with V8 (and HSV) ones? Are they all the same?
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 27-08-2008, 08:36 PM
andyman's Avatar
Master Hippo.
Ride: 05' VZ Wagon, 04 Husky TE250 & 05 Husky TE450
andyman Monaroandyman Monaro
as far as i know its like a variable resistor (if thats what there called) like in a slot car controller, a piece of metal slides over a copper rod that looks like coil, depending on the % of throttle changes the resistance changes through the metal contact
it is then basically sends that signal to the ecu which calculates the current load on the engine, how much throttle input your giving it, the gear its in, and what its revving at currently,
it then decides when appropriate to change gears, calculate injector pulse (along with other references) where to position the throttle butterfly, cam phasing and variable intake manifold (if fitted)
thats just amongst other sensor inputs etc,
as for inter compatibility, im not sure, you would think they are the same to make production lines easier but who knows
__________________
VZ Wagon - Starting to get there
>>>>>HERE<<<<<
Black 18z, Hell Yeah
My New 05' Husky TE450
--===-- My Old 04' Husky Te250
Quote:
Originally Posted by Hamish & Andy
Whats it like firing a big gun on a tank?
"like having a massive penis that shoots fireworks"
Like what you read, Then hit the scales
  #3
Old 28-08-2008, 06:23 PM
naf33n's Avatar
go
Ride: vz sv6 M6
Trade Rating: (0)
naf33n Berlina
correct expect it has two variable resistors working in opposite directions and the module takes a reading from both to determine the pedal position, and also as a saftey feature if one fails
  #4
Old 30-08-2008, 01:58 AM
1991_Vn2nV's Avatar
Cheers guys, one more question if anyone knows the answer...Not related to VE now though..
Will a pedal off a 5.7L VZ running the E40 computer be compatible with a 6L VZ running the E38 computer? As in plug and play (wiring-wise) compatible?
  #5
Old 30-08-2008, 06:28 PM
daron's Avatar
Ride: vt 2000 series 2
Trade Rating: (0)
daron Berlina
dont blow the module up for this i know my junior did it last week 1349 bux to fix so car can drive
__________________
never drive faster than your guardian angel can fly
  #6
Old 31-08-2008, 12:57 AM
1991_Vn2nV's Avatar
What module is that? It only cost me $55 for the pedal with the module and switch on it.
  #7
Old 31-08-2008, 02:59 PM
daron's Avatar
Trade Rating: (0)
daron Berlina
was a vz aloytec ecu module on motor
runs 5v only and 12v went to it
__________________
  #8
Old 31-08-2008, 05:00 PM
naf33n's Avatar
go
Ride: vz sv6 M6
Trade Rating: (0)
naf33n Berlina
most electronic modules/ sensors run off a 5 volt reference voltage, much easier to maintain 5 volts then 12, due to variable loads on the battery and battery condition
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
To all Member That Don't Drive A Commodore, What Do You Drive: Evolution_Ends_Here The Pub 57 18-08-2008 09:20 PM
to drive or not to drive- shredded cable [MR SS] VN - VP Holden Commodore (1988 - 1993) 5 29-03-2007 04:16 PM
Air under the pedal of my VS Series II 3.8L Please help ruredi VR - VS Holden Commodore (1993 - 1997) 23 12-09-2006 11:29 PM
Pedal box maginoodle VN - VP Holden Commodore (1988 - 1993) 2 23-05-2006 05:58 PM
VL pedal box for LJ torana??? QNB-895 VL Holden Commodore (1986 - 1988) 3 17-08-2005 06:48 PM
Car Credit | Car Loans | X-Man | Property Search | Credit Cards | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
