2007 VE calais with 45000km, just bought it 2 weeks ago. Cruising at 100kmh the engine just stopped and the speedo & tacho indications went to zero and the display went blank. Radio stayed on and blinkers, lights etc worked. I pulled over, nothing obvious in the engine bay and engine not overheated. Started it again ok, but the check engine warning came up. Drove off, engine seemed to be really labouring (could have been my imagination), so stopped again. Drove off again, check engine warning still up. Stopped for 5 minutes, then everything back to normal, no warnings up and driving fine.
I've read about the battery charging problems, and the battery symbol sometimes does stay up for a second or so after starting. Could the battery problem make your engine stall at 100kmh ? Any thoughts appreciated.
I still have the battery problem in mine, but it's never done what yours did. Usually mine just causes the ABS etc to fail and has a warning about it which stays on the screen, also stops my mirrors from auto dipping and resets the CD's in my stereo.
Hopefully if you get it to them soon they will see some sort of errors in the log to indicate why this happened.
i don't have a ve but if your battery wasn't charging the ecu would start to shut down all non essential items and unfortunately abs is one of them. this happened in my vs calais.
and yes when the battery runs out it doesn't matter what speed your doing cos it will cause the fuel pump to cut out. and with the ve's having electronic throttle control it makes it worse .
Chev badges are an instant fail
If it was the battery or alternator, it still would'nt be running. If the light Engine light comes on again, take it to Holden to have the fault code read
Could be ECU
If its not working, you're not hitting it hard enough.
My VS died at 100k's one day just like yours did. It was the ignition module.
the ve's have individual coils for each of the plugs, so i doubt its that
It's jsut what the VN-VS's do when a crank sensor fails. Sound like the alloytech's have a similar setup. You will see VN-VS's stoped all over the roads every Summer, I've started seeing them allready over the last couple of days
i have an ecotec and mine has been cutting out then coming straight back on wihtout starting again it happens when motor is under load or when ur giving it shit i have had the abs light come on but only once im no sure if i have big enuf battery coz mine wasnt charging because the alternator cable burnt out so changed battery , battery is out of a hz holden and these had no electronics maybe my battery is to small but happened a few times before this happened??
if EPS fail and ABS fail also, check your breaking sensors. i was in my friends mums ford focus hatch back ghia and i was doing too many hand break turns and burn outs. ended up overheating all the sensors. just went home. wet the breaks with a hose. waited 10 minutes anxiously hoping they will work again. and they did.
don't know if this helps with your post vs-6. could have disks touching the calipers and heating them, or breaking too hard? just a suggestion.
-D
P-Platers really are invincible;
that's why i keep loosing my license,
I wanna stay invincible forever!
you sound like a real smart guy doing hand brakies and burnouts in your mates mum's car......
now that you have stuffed the rotors i sm sure that she will appreciate your help in diagnosing and fixing the problems you have caused.
actually, if you read it. ABS working, EPS working.
Rotors are fine and sensors are back to working, only over heated. I am pretty smart doing hand brakies and burnouts in my mates mums car, it's a company lease car, any problems get fixed via ford, and i don't have to pay for fuel.
So yes, thanks for acknowledging i am smart (:
-D
yeah, she lets just about anyone and everyone use it. lol. she gave me it for a month as she traveled overseas. she wants people to use it as if she gets enough KMS on it she gets it back on tax, and gets the car cheaper due to using it for work.
pretty sweet deal. she knew i lost my license for speeding in it. and she still lets me use it. woop-woop.
-D
DJ-Bolan if your so smart than why are you doing a 2 year old thread dig?
Ronald Reagan (1986)
well, due to answering threads. helping people with some knowledge i have. i scrolled down to the bottom and a "similar thread" lead me to this thread. even if it is two years old. it's knowledge that people can use.
and if you trying to be a smart ass, learn punctuation then try to insult my intelligence. woop woop.
omg.
so many things to comment on i dont know where to start.
or maybe i just shut my mouth and let this guy learn the hard way.
*sigh
