Results 1 to 5 of 5
Thread: Painting Calipers..
    VE omega Commodore
    Jan 2009
    Question Painting Calipers..
    Hey Guys just got the GTS rims on my VE and there is alot of space in the wheels lol and i was just wondering if anyone has painted there calipers on there VE and if it was easy or not, or if they know of a good place to go get em done in S.A...
    Johnsy's Avatar
    Johnsy is offline ★★★★★
    HSV R8 LS3
    Oct 2005
    C/Town
    Commodore HSV
    Feb 2009
    its easy, it just takes time and patience! you can do them yourself if you have a day to spare
    VE SSV
    Sep 2007
    Don't cut corners and try and do them on the car:
    - Remove wheels,
    - Remove brake lines off calipers, (put a small plastic bag around end and seal tight with a cable tie - then put a container under this on ground to catch fluid).
    - Remove calipers
    - Pull apart calipers, removing pads, spring clips, slide assembly
    - Roll back rubbers from slide shafts and unbolt and remove shaft. (Make sure you regrease these with high temp grease when you refit them)
    - Label back of pads with lead pencil (i.e. Drivers side front inner)
    - Dont remove cylinder - tape up carefully around rubber seal with masking tape
    - Find some small rubber plugs to block off where brake lines are fitted
    - Remove rubber caps off bleed nipples, and tape over nipples with masking tape.
    - Scrub down parts with bristle brush and degreaser
    - Wipe down with prepsol or wax remover
    - Hang up somewhere and spray paint with VHT Caliper paint
    - Give them several thin coats
    - Allow to dry for at least a few hours
    - Assemble carefully
    - Refit to car
    - Refit brake lines
    - Bleed brakes (You'll need at elast 2 bottles of brake fluid)
    -BE CAREFULL NOT TO SPILL BRAKE FLUID ON THEM, AND BE READY WITH A BOTTLE OF WATER TO RINSE IF YOU DO - PAIN IS NOT CHEMICAL RESISTANT UNTIL IT HAS BEEN CURED AT HIGH TEMP.
    Oh - one last type... see if you can get the old series VHT - with a blood red cap... new stuff is crap orangy colour and not as good.... you can tell cos the cap on the new stuff is bright red.
    Here's a pic of mine:
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    A Commodore is a passion. Anything else is just a car
  1. Painting calipers
    By Philthy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-02-2008, 02:35 AM
  2. Painting calipers
    By savage1987 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2006, 07:11 PM
  3. Painting Calipers
    By COINERS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2006, 09:08 PM
  4. Painting Calipers
    By ozzie_online88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-10-2005, 08:39 AM
  5. Painting calipers
    Last Post: 03-10-2005, 08:40 PM
