Results 1 to 3 of 3
Thread: Pollen Filter for an SS VE
    VE SS (A)
    Apr 2009
    Default Pollen Filter for an SS VE
    I get unwanted smells and odours entering the cabin even when the recycle button is pressed (on my 2007 VE SS) and the service centre told me it's because I don't have a pollen filter. Is this part easy to fit for the average diy person and where can I get instructions or a workshop manual?
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    You need to remove the valance (covering over the outside part of the dash). Once removed you will see the air inlet and space for a filter. It is a rectangular shape a bit smaller than a standard air filter. The smell you are experiencing is likely to be as a result of the water not draining away from the condensor (you should see water dripping from underneth the transmission area of the car once you have parked it - after having used the a/c). Mould has very likely started to grow hence the smell. If not removed it will only get worse. The pollen filter will not reduce or prevent such odours getting into the vehicle. You need to identify the source/cause of the smell and then go about cleaning/removing it. Could be a major job though.
    It is possible to clean the drain outlets by getting under the car and in the area of the transmission (usually r/h side) you should see a black rubber tube pointing downwards, it is a couple of inches long. Sometimes by gently inserting a piece of wire and jiggling it around you can clear any blockage. Just make sure you don't have your face directly below the outlet just in case it contains dirty shitty smelly water. Good luck.
    VE SS (A)
    Apr 2009
    I don't get smells in general rather I get whatever is outside the car - sorry I may not have been clear in my earlier post. I don't understand how the absence of a pollen filter is the cause. Am I getting bad information? Surely the point of the recycle button is to stop the outside air from entering the cabin?
    When you say the dash covering do you mean the part under the steering column and above my feet?
  1. pollen filter/air con filter
    By binghy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-05-2009, 11:45 PM
  2. Pollen Filter? VY
    By aperfectcircle in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-03-2006, 11:40 PM
  3. air filter box
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2005, 09:34 PM
  4. Uni Filter
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-11-2005, 09:10 AM
  5. STandard AIr filter or K&N POD/FIlter
    By KDB1972VT in forum General
    Last Post: 29-07-2005, 11:16 AM
Tags for this Thread
